vq30det-pistons-almost-figured-out-t257392.html
i was reading this and by the time i was done we were still at the dilemma of having about 2 mm of space between the top of the piston and the deck which would make the compression too low. the stock connecting rods are 5.8 inches in length (center to center) which is 147.32 mm, and i found some rods for american V8s that were close and have a length of 5.850 inches which is 148.59 mm. that may just be enough to use the vq30det pistons but my only question is would it be safe to modify aftermarket forged rods? and just like hydrogen welding for cam regrinds can you do something similar to make the big end bore of a connecting rod smaller then bore it out to the size you need?
here is some manley rods.
http://www.summitracing.com/parts/man-14044-8/overview/
the big end bore diameter is 2.1250 in. and the stock size is 2.160 in. so it would need to be honed just a little. the big end width is wider so you can grind it down (if its safe to do so). and the pin end bore diameter is pretty close. the notes say: Designed for 22mm pin and 2.000 in. crank journal. if they mean a 22mm wrist pin then i think these rods will work with very small modifications done to them.
here is some eagle h beams.
http://www.summitracing.com/parts/esp-5 ... /overview/
these would require more modification but would be worth it for 1100hp (i would never need that much).
Big End Bore Diameter (in): 2.2250 in. stock: 2.160 in.
Pin End Bore Diameter: 0.927 in. piston wrist pin: .865 in.
Big End Width (in): 0.940 in. stock: .865 in.
Pin End Width (in): 1.060 in. stock: .700 in.
i figured i would see if this was possible because it would be a whole lot better than paying $1600 for just connecting rods
http://www.pureperformancemotorsport.co ... -rods.html
there worth it for 1600+hp (lol $1 per hp) but not all of us need anywhere near that much power.
someone with some knowledge should look this over and see if im missing something or see if this is possible
