Well, if you're going to look at aftermarket VQ pistons, you may as well look at aftermarket VH pistons. Reason I'm talking about factory VQ pistons is they're cheap... tho perhaps combined with the machining ops required to get them to fit, won't be such a cheap option anymore.elwesso wrote:Very interesting information. I wonder if anyone makes different pistons for the VQ30DET that may work better? One would think that the dish would make up for the valve reliefs in the VH pistons. maybe flycutting would need to be done if you were running cams..
Eh? Why would offset grinding the crank make you nervous? If a machine shop f*cked that up, they'd be legally obligated to replace your crank anyway.elwesso wrote:That makes me a lot less nervous knowing what I know now than offset grinding the crank.
Here's a question. Why does it have to be the VQ30DET pistons? Are they forged? The VH45 pistons have a compression height of 32mm. The VQ30DE pistons have a compression height of 30mm, IIRC. That is 2mm more clearance which should lower the compression nicely. The only real concerns are how the quench area is affected by the VQ pistons and also the cutting of the valve reliefs if needed.elwesso wrote:Ok so let me ask. If the 1.25in (or 31.75mm) is correct for the VH45 compression height, then the VQ30DET pistons should give us more room than the stock pistons have, right? Seems like theyd decompress a VH45 pretty easily with room for some sick cams. Am I missing something somewhere? The compression height on a VQ seems to be almost 2mm smaller which means it should go in with room to spare?
I really hope that Im not overlooking something terribly trivial.
Here's my reasoning, I'm not a millionaire and am therefore trying to find the cheapest possible decompression piston solution. A factory piston suitable for the job would be ideal due to being mass produced and therefore cheaper, as opposed to a small batch of custom forged pistons.sijoko wrote:Here's a question. Why does it have to be the VQ30DET pistons? Are they forged?
the piston in the picture is actually a probe forged piston that came out of a 4.6 dohc lincoln motor. I hate kb hypers with a passion.. lolYou are right, you won't notice a small difference in quench height like that when you are just making average power on a smallblock chevy, but whenever you are getting the most you can out of an engine with forced induction and your tuning is at the limit, the motor with more quench area and a smaller quench height (without banging the piston against the head) will be the one that won't give you any problems. A 400hp vortec head smallblock chevy, you won't notice... but on a 600+whp kenny belle supercharged 4.6 ford, it can mean the difference between being able to take the abuse or destroying pistons (picture). Forced induction adds a whole new variable to everything. Have any of those engines you built ran high psi at a high power level from a turbo or blower?That's all just pretty much rambling anyways, the main point of my posts have been that running a piston a quarter of an inch down in the hole is bad.ScottJackson wrote:
Say, was that second picture of the bad piston a KB hyper? It looks like one to me. I agree that when you're running decent compression for the fuel you're using, quench goes a long ways toward "quench"ing detonation. I've only built a few small block chevies, 2 ford 302s, 2 351W, 3 351Cs, and one 514. I am certainly a beginner and it appears I was wrong about the lightning engines. I must have either mis-read or mis-remembered something. I haven't done but one back-to-back test with quench and it did seem tomake a noticeable difference. It was a basic 350 chevy with 6" rods, manley forged flat tops, pocket ported Vortec heads, .530" lift hyd roller cam... yadda yadda. I went from .055-.060" quench to .030" (pistons out the hole .010 with .041" gasket). It did seem to maybe give it a tiny bit more low rpm power, but that was it. EVERYTHING else stayed exactly the same except for new gaskets and bearings. I used the old pistons and rings even. I'm not sure if the throttle response at low revs was improved from the tighter quench or the slight bump in compression. Granted, that's not the same as going from .200" to .030", but I'm still not convinced that in a forced induction engine with less than 4.5" bore size, it's that big of a deal when most of us are just wanting to make the most power for the least $$$. Of course I would take a 8.5:1 VH45 with custom dished pistons that give me quench over one with a piston with no quench and the same compression, but for the $800+ price difference, I'll deal with the small hit in low rpm torque and couple psi less max boost I can run without detonation. I'd also rather have an 8.5:1 quenchless VH45 with boost than a stock 10:1 VH45 with quench and boost. If you've got a good quench distance, I don't think it's worth giving that up for half a point of compression. But for 1.5+ pts of compression drop from 10:1, sure.
