cheap ebay headers
K
Car: 1991 GT-R32, 1993 MR-2 NA
zer0sk8ordie wrote:i have the obx header i love it when i get to around 5k it pops big flames!! but yah the egr was hard to connect too
Poppin' flames? I assume you are cat-less? If you're running cat-less, why bother to hook up the EGR in the first place?
I went to install my cat-delete pipe yesterday and then realized that i need to replace my header first (massive ball of rust and leaking at the cat). I was disappointed until i saw (today) that you could get them so cheap on ebay.
K
Steev
Car: 1992 240sx hatchback SE
acidbbg wrote:...egr basically dumps unburnt fuel back into the intake manifold which inturns cools down the intake temps..
The EGR does not recirculate unburnt fuel unless you have a dead cylinder or a poor running engine. The EGR system sends inert gas(co2) back into the intake which displaces oxygen to reduce the amount of 'burn' in the cylinder. Less oxygen to ignite the fuel is less heat and lower NOx emissions.
unknowns13
i had full megan exhaust with test pipe. a ran real well, kept up with a b16 EG pretty well but bad thing bout megans downpipe theirs no support so it just hangs and mine cracked at the flex pipe braids came loose from the exhaust shaking to much and its to damn loud after awhile
ka24deColt
Car: 95' 240sx se
does an s14 have 1 or 2 o2 censor holes?
mksue3240sx
Car: 240sx
s14 has 2 o2 sensors, one pre cat and one post cat....
Shift_Kouki
Car: 95 Nissan 240SX SE
Is the S14 cat the thing under the drivers seat? Or is that a resonator?
jaredkadrft
Car: 89 240sx
I have the obx knockoff on my s13 and have had it for 4 months so far. Even under heavy acceleration its held up fine.
Black on Gold
Does the S13 EBAY headers, have the o2 sensors on them? And i'd also have to block off the EGR crap since i dont have it eh?
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
Ok here's what I noticed.
SOHC w/ OBX header.1) the O2 sensor is rubbing on the firewall. Not to bad but if I needed to change the sensor, I would have to remove the header. If you go this rout, just do a test fit w/ O2 sensor installed, mark the spot on the fireall where O2 sensor will hit, and pound the firwall in a little.
2) The egr tube does NOT line up. To solve this, I just put the header on loosely (nuts on just a few threads) and had my dad use a prybar to pull tube over while I screwed it in, then finished bolting the header on. No biggy.
3) the header comes very close to the block right where the transmission bolts up. I think it might even be touching.
4) cat bolted right up but had to manuver the bracket a little to get the bolts in.
5) it made a big difference in the sound of my exhaust. I have a brand new cat, 2.5" piping all the way back to a 3" in dual 2.5" out magnaflow muffler. At idle it's got a very deep tone but when I get up above 4K it's a lil raspy. I like it a LOT. It does get a little anoying on the highway though. Not so anoying that I would ever stop driving it.
6) I could deffinatly feel a difference in power. Good difference. It does still fall flat after 5.5K. Thats where I shift anyway (for those "spirited" driving moments) and I'm still in the power zone after I shift so it's all good.
7) the finish was nice. Polished stainless steel. It turns into a bronze color when it warms up and stays bronze. The finish is still polished. Just make sure to clean it of fingerprints before you start it for the first time. Any residualls will stain into the finish and wont come out.
I ordered my header from tuningdepo.com off ebay. $195 shipped and it arived in 3days. ordered it on sunday it arived on wed. Deffinatly a good seller.
All in all, I like it a lot. couldn't be happier. (unless they sent me a smokin hot GF with it) but hey, beggers can't be choosers.
Soravia
Car: 2003 Audi A4 1.8T
I have an OBX knock-off for S-13 KA24DE
It required the steering joint to be un-hooked to install. I used heat wraps from Advance. Single 50' covered it from top to bottom end. Also coated it with silicone spray made for the wraps.
The CAT was naturally removed since the down pipe replaces it.I haven't notice any change in color, well most of it are covered any way. The thing cools off quicker than the engine itself.I mated it to a 3" pipe, resonator and 4" HKS Hi-Power tip.It sounds very nice. Has a very even sound across the rpm range.
For blocking the holes in it I just asked the Rainbow Muffler to weld them shut because I didn't want to wait for proper plugs and I couldn't find any in local stores. The holes are larger than 1/2" and smaller than 3/4".
silviasgp06
Car: 95 Nissan Zenki RB25 Powered
im so glad some corrected him, i was about to die laughing
Soravia
O2 Sensor on S-13 OBX I have is in stock position. It doesn't have any issues. But you can't use the stock heatshield on those headers, hence the heat wrap which looks 1,000 times better and give room to work on inside the engine bay.
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
NorCar240 wrote:yeah ive been checking into this headerhttp://cgi.ebay.com/ebaymotors...V#pic^is that the obx knock off header, or what?
is anyone else running this header, and if so, is it a good one?
That is the worst header ever...
Bigvinnie
mksue3240sx wrote:Mine is pulling real well up to 6.5 with the obx knock off, .
Highly doubt it. as long as you have the KA's half weighted crank and a stock head, you won't be making any peek power after 5800RPM...
roy23pim
Car: 1995 Nissan 240sx
thats what im goin to do also .. get that obx header and that 3" cat back from ebay also .. hopefully it'll sound decent.. we'll see
janda240sx
Car: 1995 240sx se
Well this thread's been succesfully raised from the dead. Anyway. You need to check out the Xtune header its the one I have. Heres the link to the thread I made about it. zerothread?id=384694. When you get rid of the cat. and get your 3 in. exhaust its gunna be pretty loud.
drftman
Car: 97 240sx 95 240sx
i have obx one it fits perfect. and looks and performs well
drftman
ftw
