It was a good one... haha...cmkelly wrote:I'm working on my wind tunnel now...
That's my very next mod. My car runs very strong, suspension is tight, but I'm missing something big time which is manual transmission. I'll enjoy that for a while and go for sr swap later down the road.AE86Gio15 wrote:5 spd swaps are not as hard as people make them seem. if you take your time with it you'll notice it was easy.
i believe this would be the one that goes to the resevoir on the passenger side of the fan shroud. i have no idea what it's for.cmkelly wrote:I have one question though; I have a leftover open hose now at the lower left side of the engine (facing the car). It did not have a place to connect it on the new intake. Any ideas?
the egr and pcv allow a LOT of nasty stuff to enter your intake. the egr can be blocked off without ill effect. the pcv, on the other hand, requires a vaccum source to function properly. some people will run it to a vented catch can or just put a little breather filter on it. however, this doesn't do anything to suck the dirty gas from inside the engine.biggie wrote:Never seen anyone run a filter on the valve cover release.
Never really thought of that. Not really sure if anyone would be able to actually tell a difference over time, but a good idea none-the-less.DeXteR wrote:
so, in order to get vaccum on the pcv, you'd have to run some elaborite catch can that had a vaccum on it. or you can do what i did and just run a small in-line fuel filter. it was only $4.
Guys, what biggie said is REALLY important. Make sure to get the one with this mounting point. Otherwise, you will have a hard time fitting it right.biggie wrote:The ones with the factory mounting point on the passenger's side rad support would definatley be the ones to get. Yall should point out which store or 'brand' on ebay you got them from.
you'd be able to tell the difference next time you open up your intake manifold. i didn't take my intake in to get tanked or anything, but i did a decent job of cleaning the inside. in about a year and a half or so when i take the engine back out, i suspect i'll open the intake manifold and it won't be very dirty at all.biggie wrote:Never really thought of that. Not really sure if anyone would be able to actually tell a difference over time, but a good idea none-the-less.
ABSOLUTELY! i really wish mine would have come with that mounting tab.94_240sx wrote:
Ah ok, I was assuming that you wouldn't be looking inside of it anytime.DeXteR wrote:you'd be able to tell the difference next time you open up your intake manifold. i didn't take my intake in to get tanked or anything, but i did a decent job of cleaning the inside. in about a year and a half or so when i take the engine back out, i suspect i'll open the intake manifold and it won't be very dirty at all.
we shall see.
