Just saw this on Freshalloy, rebuild kits for the KAE, with high volume oil pump, and better bearings, it's 445$ plus tax and shipping, which is for EVERYTHING!!
http://www.importperformancepa....html
Major Engine Kit: contains complete gasket set, set of pistons and rings, main bearings, rod bearings, thrust washers, timing belt, balance shaft bearings (if applicable), and a set of expansion plugs (does not contain camshaft, timing kit or oil pump). Pistons & Rings: Std., .020, .040. Bearings: Std., 10, 20, 30.
Platinum Engine Kit: (main kit as above) w/complete timing kit & oil pump
