Doh! Now I'm also gonna buy a new filter from the dealer just to see! I cut open a new 1yr. old filter and it has metal caps.REDDOG wrote:Forgot to mention I cut the factory filter when I changed it and it had the cardboard endcaps, as you described.
Is Fram making Nissan filters now?? This looks like a cut away from a Fram oil filter I saw about a year ago. They are garbage...philipa_240sx wrote:Oil Filter Photos:
New 9E000 purchased 1.5 yrs ago. This is like the original Nissan filters from a few years ago. Notice the pink anti-drainback valve. Due to age, I can no longer guarantee that newer filters of the same model have not gone to cardboard end caps as well.
OEM 65FC0B original factory filter. Notice the cardboard end caps and a black anti-drainback valve. Also notice the wider spaced holes in the metal tube inside the filter. These features might be the telltale indication you have the newer filter.
Now, the cardboard end caps do not mean the OEM filters will imminently fail. The filter proabably works just as well. However, I feel more comfortable with the sturdy metal construction of the old filters or the NAPA gold filters. I've installed a NAPA Gold 1356 filter. This filter looks much more like the good OEM 9E000 with the metal caps.
If no one has done it yet, I had BLACKSTONE LABS run a oil test on my first change.Natually expected high values for moly and silica(Ring breakin and cast sand.)It tested very nice.Beagle_Hauler wrote: Am just a few hundred miles from my first oil change and am willing to try synthetic oil. I have never used synthetic in my other cars, but have always heard good things. Am curious if anyone here has filled up with synthetic oil yet and have noticed any changes. I understand older vehicles have oil seals that are not designed for synthetic oil and they breakdown and leak, but our Rogue's engines should be new enough that they have seals that resist both conventional and synthetic oil.
Are you saying that Rogues are coming with syn. 0w20 or 5w30?? Do you know what brand?? My owners manual only says to use 5w30. I am going to my dealer for my 1 year service and I am going to ask that question...mstrmstr wrote:
FACTORY OIL USED Silkolene synthetic 0w-20..
Yes, its a fact now that Rogues come with synthetic oil right from the factory
Yes the Rogue hits the streets with a initial belly full of synthetic break in oil.wbloomfield wrote:
If the Rogue factory Fill is this special, I don't understand why not leaving it in the crankcase as long as prescribed.mstrmstr wrote:Yes the Rogue hits the streets with a initial belly full of synthetic break in oil.
MFG is Silkolene(not common in the US) weight is 0w-20 it is formulated with very high detergents and is very thin which allows fast drainback and the ability to flush those initial contaminants into the oil pan where the filter can take them out.
In my opinion the first oil change should be over 1000 miles but I don't think 3750 should be the target until AFTER the first one. I believe the breakin oil need a bit of mileage to do its work. 1000-2000 sounds better and then change to your favorite brand of operating lubricant.
The problem with OAI lab is they don't really read the information you send with the sample and later ask:" Please provide unit model number as we may compare data to the proper standard for this units"mstrmstr wrote:I noticed on your report that the sump capacity was listed at six yet the Rogue pan capacity is about 4.5 quarts.. yours must be liters?
Your viscosity is LOW even with a ok tbn(detergent/additives level) this is a result of the fuel in the oil. I run lab every other change on my engines.. every change on my farm equipment due to the harsh running environment.My last bog tractor cost 225,000 us USED.. when rings/bearings etc are going bad, I know before engine failure by doing the lab..cheap in that respect.
This information is for engines in general or is it specific to our engine, the QR25DE?mstrmstr wrote: Aluminum: Pistons, bearings, cases (heads & blocks).Chromium: Rings, a trace element in steel.Iron: Cylinders, rotating shafts, the valve train, and any steel part sharing the oil.Copper: Brass or bronze parts, copper bushings, bearings, oil coolers, also an additive in some gasoline engine oils.Lead: Bearings.Tin: Bearings, bronze parts, piston coatings.Molybdenum: Anti-wear additive, coating on some new rings(washes off as break-in occurs).Nickel: Trace element in steel.Manganese: Trace element, additive in gasoline.Silver: Trace element.Titanium: Trace element.Potassium: Antifreeze inhibitor, additive in some oil types.Boron: Detergent/dispersant additive, antifreeze inhibitors.Silicon: Airborne dirt, sealers, gaskets, antifreeze inhibitors.Sodium: Antifreeze inhibitors, additive in some gasoline engine oils.Calcium: Detergent/dispersant additive.Magnesium: Detergent/dispersant additive.Phosphorus: Anti-wear additive.Zinc: Anti-wear additive.Barium: Detergent/dispersant additive.
Answer, general information for automotive gasoline enginesCommon automotive gasoline engine oil lab findings
Synthetic oil can flow better in cold weather helping to lubricate the engine faster.kerrton wrote:I'm considering changing to synthetic, and have some questions to determine if this is worthwhile or not.
1) Does the Nissan dealer offer the synthetic option, or do they only offer the standard conventional oil? Some Nissan dealers offer Mobil 1 as an optional synthetic oil. Not my favorite oil as it seems to make the engine a bit more noisy at startup. I use Castrol Syntec 0W30.
Quote »2) I live in a cold climate and am worried about cold starts and the wear it causes, do you feel that synthetic offers better protection for cold starts, or is all the oil in the pan regardless of type of oil and cold starts are just bad no matter what type of oil you use? I also do a lot of start/stops regardless of temperature, so perhaps synthetic would be beneficial?
While it may be seeing more widespread use in the last 5 years or so its actually been around for a LONG time. 35 Years to be exact! Mobile 1 was introduced of Exxon Mobil was introduced back in 1974. Its claim to fame was 25,000 miles between oil changes.Beagle_Hauler wrote: Synthetic has been in fairly widespread use for oh, around five or six years now.
Hmmm. that's a loaded question. If you as 10 different people you might get 10 different answers. (Some answers based on personal opinion, some based on education, some on experience, some just plain guessing )sckeith wrote:At what point would you not put synthetic oil in your cars. I have a 2008 Rogue that I will start using synthetic oil in our next change but also have a 2005 Toyota Solara convertible with 120,000 kms or 75,000 miles. I don't want to put any big time money in the Solara because we're retiring in 3 to 4 years
Thanks
