tsumeone wrote:Man 26/27 city driving... makes me think I should take mine to the dealer. I get ~16-22 city driving and that is driving it very conservatively. Been like this since I bought it. You live somewhere incredibly flat?
As the Rogue is made in America, using an American-made engine, I wonder if the technical writers who wrote the manual (who tend not to be engineers) got the conversion to metric wrong. Looks like they just used 0.9 for the conversion and rounded.mikess wrote:Nissan's calculations are all wrong. The oil with filter change is 5-1/8 qt however, the amount in liters is 4.6 L. Which doesn't equal the same amount. 4.6 L is equivalent to 4-7/8 qt. So much for Nissan engineering they messed up the quantity conversion in the 2014 Rogue Owner's Manual. Those two amounts don't match. If it was indeed 5-1/8 qt that would equal to 4.85006 Liters. Lol, and engineers know what's best for the engines.
Interested in knowing how this goes for you. I hope to go to the 0W-20 next go around, I'm at 8800 miles, so about 1200 to go for the next change.mag318 wrote:Went in for my first oil change at 2000 miles and after doing painstaking research I decided to go with the recommended 0W-20 instead of the 5W-30. Since my first oil change was suppose to be free I insisted on 0W-20 and watched my mechanic bring out a six pack of Mobil 1 instead of whatever their default oil is. It did indeed take 5 and 1/8 quarts and the mechanic told me they did some changes like possibly a larger oil pan. Anyway the engine feels even smoother than before and I'll keep track of my mileage to see how it progresses as the engine really breaks in.
Made in 'Merica but undoubtedly engineered 100% in metric.As the Rogue is made in America, using an American-made engine, I wonder if the technical writers who wrote the manual (who tend not to be engineers) got the conversion to metric wrong.
the higher mileage, the less likely i'd be using synth. id be using conventional- maybe even thicker blend (10w-30). your seals wont suffer from synth oil. they will leak because they are slightly worn and synth oil can fit between places conventional typical wont/cant.MercuryAlpha wrote:Sorry all, I hate to resurface a thread that has been dead for over a year, but this is for anyone who moved over to full synthetic. Do any of you do anything differently once you start getting up to higher mileage on your Rogue? If you switched to the higher detergent blend full synthetics early on, is there any concern about seal wear due to continued use of synthetics once the miles start getting up there? If so, any recommendations?
Cheers!
~MercuryAlpha
Modern engines and conventional oil can safely be changed at 5k mile intervals, and modern engines with synthetic oil can safely be change at 7k miles.therealroland wrote:Using synthetic should allow for longer oil change intervals. My sticker says 5000 miles until the first service. I think rule of thumb with conventional oil is 3000 miles?
you dont need synthetic. you could easily get away with conventional every 5k.CapeCodChips wrote:My dealership does a full synthetic oil change and filter for $41.33, including tax. I would be nuts to do this myself.
They used to use Mobile1, but now have switched to GULF 0W20 Synthetic-0W20G-T.
I'm doing the oil change every 5,000 miles. Any thoughts on the oil?
2014 Rogue SV 47,000 miles.
Thanks
Which filter #? Depending on the source, I am finding different filter numbers that cross reference to the Nissan OEM oil filter #.whizkidtn wrote:I always change the oil myself, use M1 0W-30 full synthetic (purchased in 5QT jug at Walmart for $26) and use the PureOne oil filter ($7 from AdvanceAuto).
Yup, it's the PL14612.Lone Wolff wrote:Which filter #? Depending on the source, I am finding different filter numbers that cross reference to the Nissan OEM oil filter #.whizkidtn wrote:I always change the oil myself, use M1 0W-30 full synthetic (purchased in 5QT jug at Walmart for $26) and use the PureOne oil filter ($7 from AdvanceAuto).
I am running PureOne PL14612 on my Honda 919, and it looks like maybe the same filter is OK for the 2015 Rogue?
Dealer did my 1st change for free but next one I am doing myself.
TIA.
its on the passenger side, under the car. you can see it if you move the mud flap behind the right front tire.engineer20 wrote:WHere is the oil filter to the rogue? I went down there to look but couldn't find it.
Diagrams and pictures would be nice.
The number one forum on the internet for oil questions is; REDACTED!. Check it out and you will find plenty of examples where owners have switched between synthetic and conventional without any problems. The 2015 Rogue manual says 0W-20 synthetic or 5W-30 conventional can be used. I'm coming up on my first oil change for my 2015 Rogue and plan on having the dealer use the 5W-30. At a max of 5,000 miles on the oil change interval, there's no real advantage to the higher cost of synthetic.mtbkr1030 wrote:All,
I used syn oil for the first couple oil changes and the last one I had them use reg oil. Has anyone converted to regular oil?
Just curious.
My vehicle has 25K on it and so far has been very reliable.
Tom
I SWITCH BETWEEN SEASONS. summer months i give it conventional 5w-30. winter months i switch to full synth 0w-30 to keep the oil really thin & fluid upon cold start-ups.mtbkr1030 wrote:All,
Just curious.
Tom
