CHATROOM: Engine Fan Serpentine Belt
di_gent
Car: 2008 Nissan Rogue SL FWD
Unfortunately just like every thing else we get taken advantage living in Canada :tisk: :bs: :bs: . Its $57.90 the shipping is $22.50 :wtf2: !! Its a belt how could it possibly cost $22.50 to ship!1 :mad: :mad: :mad: :mad: But thanks for the info :dblthumb:
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
di_gent wrote:Unfortunately just like every thing else we get taken advantage living in Canada :tisk: :bs: :bs: . Its $57.90 the shipping is $22.50 :wtf2: !! Its a belt how could it possibly cost $22.50 to ship!1 :mad: :mad: :mad: :mad: But thanks for the info :dblthumb:
Because it's shipping from the US into Canada so it has to go through Customs (extra $, they say). That is kind of high for a 1lb package though...
cinzunza
Car: Nissan Rogue SL 2WD 2011
I need a new drive belt for my 2011 Rogue SL 2WD and as far as I understands, the original part number it needs is 11720-JG30A, however I have been offered P/N 11720-JG30B...does anyone know if there's any difference? Is it safe to go with the "-B" part number?
Thanks.
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
welcome to the board. we have a thread already open for you: post6637009.html
if the dealer is pushing a newer model number, its probably because they changed a small thing about the original part, and its more or a less a "fix" the older part was having. plenty parts get update this way
ImStricken06
2016 Kia Sorento
victor_26
Car: Nissan rogue
Hey guys,
I have a Nissan Rogue, 2008, which has a serpentine belts with the little staggered-cog features. See pic on Amazon, . So unlike the normal belt that you can virtually see the cracks on it, this one is hard to tell. Anyone has a clue to check the belt? Thanks
http://www.amazon.com/Poly-V-Serpentine ... B000C32IUK
Reason: Merged with existing thread
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
victor_26 wrote:Hey guys,
Hello and welcome to NICOClub! We have an incredible SEARCH feature on this forum. I've merged your thread with the most relavant one. please take a moment to read it and the ones listed below.
--------> READ BEFORE CREATING NEW THREAD! <--------
Serpentine Belt and CVT Fluid change?
2010 Rogue serperntine belt
Engine Belts Shot after 27K Miles???
drive belt
victor_26
Car: Nissan rogue
Hi guys,
I have a "Continental Elite 4060882 Poly-V Belt" on my engine. It has a helical cog texture on it which makes it hard to tell if it's cracked or not. Anyone has similar experience and know when to replace it?
Thanks a lot for help
Rogue One
2022 Honda Pilot SE
victor_26 wrote:Hi guys,
drive belt
ImStricken06
2016 Kia Sorento
replace it with an OEM belt bro. that belt you have there, lacks contact patch.
[youtube]http://www.youtube.com/watch?v=G4e3AjWJ3us[/youtube]
logster
Car: 2009 Nissan Rogue S AWD
Awesome video. Thanks for that and all the comments that followed. I have a 2009 Rogue with 53k miles but it has been back at Nissan at Nissan many times these past 2 years for recalls and warranty work and every time since it hit 40k they have been telling me to pay them $140 to change the belt because it was in very bad shape so I decided to follow the video and service manual and do it myself.
I did not have the OEM but the Goodyear Gatorback 6PK1805 (I think is costs $7.19 on Amazon) and I can confirm that it is a few mm shorter (1805mm for the 6PK1805 vs 1808mm for the 11720-JG30B) but still installs within specs
Had some trouble installing because I was trying to get it around the crankshaft and tensioner as the last step. But as the manual says (step 3 of installation), do the water pump last. Doing so, I was able to get it in place but having no help around, had to use 2 extensions and a breaker bar that I basically sat on while holding the top end with one hand and slipped the belt over the water pump using the circular part of the jack handle. Should have had a helper or just gotten the OEM belt.
Thanks for all the information on this forum
logster
cinzunza wrote:I need a new drive belt for my 2011 Rogue SL 2WD and as far as I understands, the original part number it needs is 11720-JG30A, however I have been offered P/N 11720-JG30B...does anyone know if there's any difference? Is it safe to go with the "-B" part number?
Thanks.
I believe the B adds support for the 2015 Rogues.
rowlands57
Reviving this older thread to share my experience after reviewing all the great information here and the excellent YouTube video.
I ended up using the Driveworks belt from Advance Auto as it was what was available when I decided to do the job. It is also about 1805mm but it worked fine once installed. It turns out that even at 144K miles the original belt was in decent shape, likely because most of the driving is highway so things are kept a bit cooler under the hood.
When installing it solo I found that I was able to hold the tensioner properly while using the A/C compressor as my last pully to put the belt around. I was a bit cross armed but was able to do it with just my 3/8 ratchet for leverage. I did have to push the tensioner all the way, but it worked out just fine with a little effort. I found that this allowed me to line the belt up properly on the up top pullys and I was able to focus on just the one for the final push.
Thanks again to all who preceeded me on this for sharing your experiences.
Lone Wolff
Car: 2015 Nissan Rogue SL AWD
2025 Toyota Corolla Hybrid
2010 Ford F150 Lariat 4x4 5.4L
2010 Ford Fusion SEL
1968 Firebird 400
Just an FYI for owners of 2014 - 2017 Rogues (maybe newer, can't confirm)..The part number(s) listed previously in this thread are not the correct ones for the newer Rogue. OEM Nissan part number for the serpentine belt is 11720-4BA0A.
Return to “Rogue Forum”
