Ace2cool wrote:Just basic relocations, like battery and fuse block. Other than that, you pretty much nailed all of what I would recommend. Since you already have the battery tray out, the battery relocation should be pretty simple.
The heatshield needs to come off, yes. Was that bracket on the interior? I didn't remove it for mine. I used a 1/2" 3' extension and ovalized the firewall hole slightly by working it around, then taped the white connector back (facing opposite the blue connector) and was able to snake every thing in. Pushed the blue thru, then pulled from the inside.Chase300 wrote:what i researched when putting the new harness in was to wrap it up with duct tape and cover it with vaseline and jam it in the hole
Shootin for 500. That would tinkle me pink if i could achieve that. Ya send me a PM next time your comin this way and we'll go for a rip. Should be drivable in a week or two, just waiting on a few things like hicas bar and p/s pump .. alternator ect.AllGoNShow wrote:Looks awesome! Sorry if I missed it, what kind of power are you expecting?
I rip through Red Deer all the time, never stop anymore but once this beast this together we should definitely find some time to meet up, would love to check it out in person.
what's your setup, chase?Chase300 wrote:Shootin for 500. That would tinkle me pink if i could achieve that. Ya send me a PM next time your comin this way and we'll go for a rip. Should be drivable in a week or two, just waiting on a few things like hicas bar and p/s pump .. alternator ect.AllGoNShow wrote:Looks awesome! Sorry if I missed it, what kind of power are you expecting?
very niceChase300 wrote:Shootin for 500. That would tinkle me pink if i could achieve that. Ya send me a PM next time your comin this way and we'll go for a rip. Should be drivable in a week or two, just waiting on a few things like hicas bar and p/s pump .. alternator ect.AllGoNShow wrote:Looks awesome! Sorry if I missed it, what kind of power are you expecting?
Vulcan -> Im also running automatic for now.vulcanrush wrote:what's your setup, chase?
i'm trying for 450rwhp+, and that's with jwt550bb's, 2.5'' ic and ic pipings, 3'' exhausts, ferrea valves 1mm+, jwt500 cams.
i also have an auto transmission, and those tend to eat up more power.
are you shooting for 500 on regular gas?
20-psi on regular gas???? that's a recipe for knock.Chase300 wrote:Vulcan -> Im also running automatic for now.vulcanrush wrote:what's your setup, chase?
avs sidemounts
2.5 megan downpipes
2.5 megan testpipes
550cc jecs injectors
jwt ecu tune
unorthodox lightweight drive pulley
a/c delete
.5mm overbore
87.5mm wiseco pistons
eagle rods
ferrea 1mm oversize valves
supertech dualsprings
ported heads
jwt sport 500 turbos
ported exhaust manifolds
ported intake manifolds
jwt single cone intake kit
sz flexplate
going to run about 20psi of boost (probably all i can get out of sport 500s)
the link is to a post by greg dupree of specialtyz, where he says, typically, 17-psi on 93-octane, and 18-psi on 94-octane.Chase300 wrote:i run 94 octane from husky. I should be safe. Whats that link to? i dont have a account there
