Changing Knock Sensor KA24DE couple questions
MYFREE95,240SX
Car: 1995 NISSAN 240sx KA24DE 1995 NISSAN 240SX ka24de yes two of them
1. Stupid question but i cant really find the symptoms of a bad knock sensor i pulled the code. can someone describe the symptoms?2. 3rd gear shift sensor how important is that? 3. fsm dosent really say where it is but i believe the knock sensor is right in the front of block on passenger side correct?4. could timing chain rattle cause knock sensor to throw code?
MYFREE95,240SX
FIGURED OUT WHERE IT IS WTF!
vancouverbc
Car: 1991 240sx
see the tutorial for location in my signature
driftneil
Car: A pile of cars.
You have to pull the mani, but alot of things will give a false knock sensor code.
MYFREE95,240SX
def didnt need to remove manifold any one who does is stupid check this site for a better way took all of 20 min. bump for the link
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Knock sensor should only be replaced if it is physically broken. The other very random symptom that throws a Knock code is if the harness to the knock sensor has a break in it. Otherwise the knock sensor code is a dummy code that should tell the technician that there is an underlying problem causing the knock. Depending on what and how loud it is rattling, the chain might set a code, but I doubt it.
Do you have a check engine light on?3rd gear shift sensor? is it auto?Has the car been sitting a while?
If the check engine light is on then get the codes and that will tell you what to fix or replace.
As far as stupidity goes...If you replaced the knock sensor already, then I would say that you are the stupid one unless it was cracked or otherwise physically broken...
Searching Knock sensor didnt come to mind though did it????
zerothread?id=447707
Modified by blacksrjdm at 10:16 AM 9/18/2009
