extheflow »
https://forums.nicoclub.com/extheflow-u3097.html
Wed Feb 25, 2004 11:46 am
i took out the whole airbag system, then the dash, then the airbag warning light.you have to remove the dash to get all the hardware off and remove the airbag and brackets, and weld the bracket to the horizontal structural member. it's pretty intense.also the metal thats on the bottom of the airbag lid is like NASA supermetal or something. i tried 3 different epoxies and none of those stuck, you can't even weld to it. i ended up drilling it and using rivets to attach the hardware for the hinge and motor arm. now that i know how to do it it would still take a good 10 hours to do.
