LOL!yessir240 wrote:if you cant beat TEH cavy you are TEH suck TEH new muffler is TEH word whatTEH kind, Yea TEH new muff muff will add atleast 20 hp and give you teh nos, now get to TEH racing...................................WHAT THE HELL IS TEH??????????????????????????????????
Your name is ironic considering you think that "good plugs and wires" are a useful modification.Riceless wrote:LOL!
Please don't put a muffler on an auto. The car will never be FAST naturally aspirated/auto, so don't give us nissan owners a bad (worse) name. If you must do something maybe a drop-in air filter, Z32 fuel filter and a good set of plugs and wires. Then manual swap, then turbo, THEN full exhaust. I'm sure you are on a budget, but anything else is a waste. I don't mean to flame, just saying it like it is.
You should beat him regardless.
OE replacement plugs and wires are just fine. You don't need some ridiculous $200 plug wires and uber platinum iridium x4 plugs of doom!Riceless wrote:****ty ignition will screw you over. Good luck going anywhere with old wires and antique plugs.
Your seriously stupid if you think an auto can't be fast.Riceless wrote:LOL!
That's exactly what I was thinking about doing. I tried it at a few red lights today on the way back from work. It seemed to get over that initial hesitation of being floored and shifted to secound faster. It's just a weird feeling when you feel the back end push under and the brakes making that clinking noise. Not somthing I wanna do on a regualr basis.jt15833 wrote: how are you going to launch? hold brake and gas and let go of brake?
A z32 fuel filter will get you nothing when it comes to performance. Also, it is not impossible to have a fast NA car with an automatic transmission. You are afraid he is going to give Nissan owners a bad name, but by giving him wrong information you sure aren't helping very much...Riceless wrote:Please don't put a muffler on an auto. The car will never be FAST naturally aspirated/auto, so don't give us nissan owners a bad (worse) name. If you must do something maybe a drop-in air filter, Z32 fuel filter and a good set of plugs and wires. Then manual swap, then turbo, THEN full exhaust. I'm sure you are on a budget, but anything else is a waste. I don't mean to flame, just saying it like it is.
Thanks for the good advise man.. I've learned a lot about my car in the few weeks I've been a member. I do however have to get a new muffler since my current one has rust holes and sounds loud as can be. Wont pass insepection as is. What I'll do is talk it over with my local muffler guy and tell him I plan to upgrade to a 2.5inch exhaust an put it on with that in mind. I'll slowly start ordering the rest of the exhaust with that in mind and have it ready for when I drop a new header in or have it installed before.naed240sx wrote:Swapping out the muffler wont make but maybe 1 pony. Plus, it will sound like #### because the rest of the piping will be stock. I reccomend buying a cheap straight-through muffler, and getting a exhaust shop to custom make you a system. I would go for 2.5 inches, high flow cat, and a new header if you want. DONT use a test pipe, it will be loud as hell, and you will be sure to lose some low end. For the whole exhaust system, you could either go custom and spend around 300 dollars(just make sure they hardly bend the pipe, because they wont use mandrel bends) or go with a premade brm system.
BTW, what your wife cant learn to drive stick?5-speed swap would make a world of difference
Just don't neutral drop it. If you plan to continue to footbrake it, you'll definately want to upgrade the torque convertor. I'm not sure what the stall speed of the stock convertor is but I wouldn't rev it too high. (I'd play it safe and say no more then 1k to 1.5k rpms)komete wrote:
