longhornsqx4 wrote:Its guaranteed to throw a CEL if you ditch all of the cats?
Would I still pass emissions if I removed the secondaries?
I was going to remove all 4 and then just pay a guy the extra coin for the fake e-test, but if replacing only 2 would give me the same gain...... then I might do it...
But Im sure the primary cats are still a good restriction...
Yes, you will have a CEL.
You may be able to pass the sniffer without the secondaries. With a little tweaking, and an engine in top shape, you should be able to make it pass. That being said, if there is a visual inspection, you will fail.
Cats are not nearly the restriction people make them out to be. There are many more effective ways of making power, especially when working on a truck engine. You are neither running high revs, nor a turbocharger, so a little restriction isn't the end of the world.
You want more power? Open your intake, reduce parasitic loss, and start thinking about forced induction.
Also remember, this is a truck, so you should be trying to make more usable torque, instead of top end power.
