jt15833 »
https://forums.nicoclub.com/jt15833-u30482.html
Sun Feb 18, 2007 3:40 pm
i too, tried for a very long time to get this off, using every method i read/heard about with little luck. some ppl say it slides of (use penetrating oil), but mine didnt. some say pry from all sides with screwdrivers / pry bars. no luck. some say heat it then remove, but mine didnt come. finally, i drilled 2 holes opposite of eachother, tapped them, then used a slide hammer and 2 bolts to remove it. it was by far the cleanest / most effective method. it would be very hard to damage something important with this method, mainly the crank. you will of course, need a new timing cog. heres the remains of mine.
PS - make sure you get the new timing belt guide peice that goes infront and behind the cog before you put the new cog on, or else youll have to remove the cog again. you can reuse the old one however. its skinny and looks like a donut, with a small rectangle cut out on the inside. id recomend new woodruff key too.
