My Silvia has a Cat temperature sensor that's no longer hooked up. Does anyone know if there is some type of enrichment table that adds fuel if the cat's temp is too low?
I also have a Z32 AFM, I'm not sure how it's wired however I am experiencing a rich idle condition. I'm trying to narrow down if it's the AFM wiring where I need a resistor added or if I need to intercept the catalytic temp signal and trick the ECU into thinking it's fine...
For those with Silvia's or 180sx's what did you do with your cat egt?
Nico: Z32 AFM wiring ->
rb20-25-n60-n62-maf-to-ca-wiring-guide-t256699.html
Nistune: non-lambda wiring ->
http://forum.nistune.com/viewtopic.php? ... 18&start=0
lambda vs non-lambda ->
http://forum.nistune.com/viewtopic.php? ... &view=next
edit: changed title, original post and added links as I find it through google
