carb?
willismcbride07
Car: 240sx
hey guys just got bored with the same old discussions so i figure id give ya some room for thought? what about a carb on a ka would it be poss and what would it take, would it be better or worse and what about with a turbo of supercharger would it help with the tuning part or be worse, what kind of carb? side mount or topmount just figure id try to spice things up a little maybe a stupid question but hey we got to search all options.
h.240
Car: 1991 240sx hatchback
Here's a thread that was started a little while ago about this - zerothread?id=331618. Not too much was determined, but there is some useful information. Datsun forums would probably be a better place to get more information, since they use the Ka for engine swaps into some of the older cars. I think it would be pretty cool to do, but the carbs can cost a lot.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
they do use (carbs) persay..in japan and in some race classes in the states..but there called (ITB's)..as in individual throttle body's..basicly 4 carbs linked together one on each intake...not only looks really cool..but can add horsepower if done right..tuning is a ***** thou.
liquid_cool
ps......it is one way of working around the ka24de's intake manifold issue...but expencive..unless you can scavenge some carbs from a motorcycle junk yard.
spank044
Car: 1992 240sx with a Supercharged 350Z VQ for a HEART!
liquid_cool wrote:they do use (carbs) persay..in japan and in some race classes in the states..but there called (ITB's)..as in individual throttle body's..basicly 4 carbs linked together one on each intake...not only looks really cool..but can add horsepower if done right..tuning is a ***** thou.
Silly newb, ITB's are fuel injected. If there are four mikuni's or something similiar then they are still carbs. ITB run best with full standalone ecu's. RB26DETT have ITB's from the factory even.
Also for the carbs your going to want to run shorter runners and need to modify the intake manifold.
OP be different and run four impco LP carbs. They are good for 125 hp a piece and LP runs cleaner and you an advance your timing for even more power.
liquid_cool
wow man..where have you been...ITB...Individual Throttle Body..yes some are FI..but not all..havent you ever heard of side-fed carbs or side draft...incredible and you call me a newb...ITB's have been use'd long before your time and long before Fuel Injection..you need to do some reaserch in to classic stock cars and classic Road racing...just becouse im an old bastage dosent mean im not in the know guy..you might wana start in datsun forums..there are tones of tuners there..thats understand the side fed carb/itb principal...end of story..(insert rude comment and bad words here)
spank044
liquid_cool wrote:side-fed carbs, they do use (carbs) persay
Exactly, side fed carb's are still carbs and have throttle plates to control airflow which in turn control fuel flow. Want a cookie? Throttle plates are part of the carb therefore it is still a carb. Throttle bodies are just the butterfly with a tps on the end.
liquid_cool
man..i guess your gona flam me no matter what i say..read my original post..ya its still a carb with a throttle body attached..all bodys are attached..hence itb..individual throttle bodys...its the same..so flaming me down makes no point other than to be rude to a forum member for really no reason..its pointless....keep your cookie.
