ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Mon Jun 07, 2004 5:36 am
This is a very common problem that most of us have, yet noone seems to ever know how to fix it.
Everyone will tell you a different solution that they've heard might fix it, but noone ever really knows.
Well, my car used to do it, but it doesn't now.
After trying everything under the sun. Removed and cleaned the IACV, removed the AIV, checked and cleaned the MAF, checked the TPS, changed plugs, O2 sensor, etc. The solution came by accident whenever I turbocharged my car. I removed the EGR system because I didn't want to put an EGR bung in my downpipe, and the idle problem went away. The EGR recirculates exhaust gas into the intake manifold to help warm things up faster, and reduce emmissions. My theory, is that the diaphragm that controls the EGR gets kind of sticky after a while. When you let off the gas, it lets too much exhaust back into the manifold and kind of chokes the engine out. One of the tests to see if your EGR is working is to reach up under the diaphragm, and push it up...if your engine bogs down, then the EGR system is working. I think, as our cars get older, the diaphragm just doesn't work quite right anymore, and results in the bog at idle. I removed my entire system, and made a block off plate for the intake manifold, and my car idles great now. I used to blip the throttle every time i put the clutch in to keep the car from bogging, but those days are over now.
Like I said, this is just my theory, and I haven't varified it on any other cars.
Hope this info helps.
