IDriveFords »
https://forums.nicoclub.com/idrivefords-u50137.html
Wed Apr 04, 2007 4:18 pm
Ok so I finally get my SR running but not completely. It does start and it runs for maybe about 5 seconds then dies. The plug in cyl#1 kept getting fouled but I'm almost positive its from the motor sitting for so long. When I pull the plug and crank it sometimes some dust will puff out. I did another compression test just to be 100% sure I wasn't loosing compression in that cyl and the test came out cyl#1: 130, cyl#2: 130, cyl#3: 150, and cyl#4: 140, so the compression appears to be fine. My only other thoughts are maybe the injector in cyl#1 is clogged or the timing is still a bit off. I've gone back and forth with the timing now and the damned thing still wont stay running. Anyone got any ideas?
