car starts and dies
luis741953
Car: 1995 nissan 240sx se
hey here is my problem, my car will start but will not stay on, it will just die 1 second after it starts,i try to give it gas but nothing happens like somethingis telling my POWER FC not to activate my fuel injectors i've checked maf got 12 volts on power lead, replaced fuel filter checked fuel pump, fuel has pressure after the fuel filter, could it be a clog in the fuel line after the fuel filter?? please direct me in the right direction, also does the power fc give you engine codes?? ( when i go to sensor check in my pfc AF is lit im not sure if this is normal, when i start the motor FP and VTC light up...any help is appreciatedthanks
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
check to make sure the injectors are pulsing.
who did your base tuning.
luis741953
i got a basemap from enthalpy, what signal tells the ecu to pulse the injectors?
if the injectors are not pulsing, whatcould be the problem??
IanS
Im confused, what is your setup, what all do you have done to the car.
luis741953
my bad
i have s14 blacktopstock t28 turbostock injectorsgreddy fmic3 inch full exhausthks ssqwalbro 255 fuel pumpz32 fuel filterApexi power intakeapexi avcrPower fc
the map is from enthalpy website..could it be my maf or TPS??
or maybe the wire that sends injector pulse has an open somewhere??if that was the problem wouldit even start??thanks
luis741953
anyone??
