TheOne wrote:it should actually be 2/2, as Z32 MAF on safc is 2.
My ECU is tuned for a Z32 MAF and 2/2 works fine. No need to 'trick' the ECU if it's already tuned for it. As stated above, the Z32 MAF is '2' on the SAFC II. Now, if you have an SAFC I or whatever with the knobs, I have no idea. But it sounds like you have the number two.
Food for thought. Enjoy..
*Edit* Also, do you have a wideband? I know your car will sputter, and detonate if you run it lean. Maybe adding the fuel helps because of this 'lean' condition. Check it out, get back with us.
