kamikazee47 wrote:i bought new plugs and gap them to .032 inch and nothing changed
Try a lower gap. At some point, it will either solve the problem or be clear that the spark isn't the issue. It doesn't cost anything to try it so in an effort to rule out one possible cause, this should be a no brainer.
Bear in mind though, this is almost always the cause of the symptoms you describe. Many people experience it and don't consider the spark to be the issue. And it is a problem that gets worse with more boost. I didn't see what kind of boost you are running, but with the inkjectors and MAF you are running, it's safe to say that you might be running a moderately high boost level. The more boost you run, the more resistance there is between the electrodes. If gapping the plugs down more solves the problem, I'd seriously consider upgrading the ignition. This way you can open the gap back up a bit more as well.
