My 2000 would stall when I would visit my mother. I would come to a stop on a slight down hill slant, and it would just die. No codes, my buddy the infiniti tech correctly took an educated guess it was the IAV and was correct. Something cheap you could start with is running seafoam through the motor. My I was running really rough in the morning and almost stalled, ran some seafoam through the brake's vacuum line and now it idles perfect.
Edit I just noticed this topic is yearrrrrrrrrs old lol...
The engine in my 2000 Max just started shutting off as well at low idle. No engine codes. Mechanic has just replaced the positive cable clamp to the battery and took it on a test drive. Had no problem previously. They charged the battery, but did not clear the problem. Anybody have any thoughts????
So why did he replace the clamp in the first place? Not sure if that would cause a stall, a bad connection would probably seem like you have a weak battery.
