ceningolmo wrote:Try these two NICO articles on for size.
The first one is by Chopp, and is probably the most applicable to what you are trying to do.
http://www.nicoclub.com/articles.php?id=183170
The second one is by me, from a while back. It's much more intensive and is probably more work than you want.
zerothread/225181
Excellent write-ups.
When I was younger and drove new Corvettes, I was anal about caring for them. Since the paint on a fiberglass car cannot be baked, it is heat-dried and air cured. That paint is nowhere near as hard and durable as a good baked OEM finish (and neither is a custome repaint, no matter how expensive).
I spent all day every two or three months, and reguarly put on 6 to 8 coats of good carnuaba wax. The (silver, all of them) paint eventually oxidized no matter how I tried to protect it, but my work did prolong the time before the Phoenix sun beat it up. Unfortunately, I'm physically unable to do it all any more.
Here are three tips I learned during this odyssey of car mania:
1. To keep the car from attracting and holding dust when finished, do a final quick rinse and buff dry with a fresh, clean, dry terrycloth towel after finishing the last step of waxing. That removes any remaining petroleum by-products left over from the waxing/polishing products.
2. Use an old, preferalby medium bristle toothbrush to get the dried wax/polish from cracks, nooks and crannies, especially around windshield and backlight trim and around emblems.
3. Clean all glass from inside with glass cleaner, using paper towels. Here's the secret to making the glass truly clean and clear: immediately after drying, while there is still some residual moisture on the glass, make a large pad of Kleenex and use it to buff the glass competely dry, especially in the corners. Keep one sheet for positioning against your hand so you don't introduce oil from your skin into the Kleenex and onto the glass. Turn the sheets on the pad frequently (I use 8 to 10 sheets and rotate them using the face of each sheet in turn) to keep presenting a clean dry surface to the glass. Use a separate pad for each window. This completely removes that oily film that leaves a blue haze on the inside of the glass which is caused by the evaporation of the volatiles/aromatics in the plastics used in the interior of the car. It's critical to keep presenting a fresh surface of Kleenex to the glass to actually remove the film, rather than just spreading it around. Usually, two complete repeats of the entire process is necessary if not done regularly. That oily haze is stubborn.Use the same finishing up process with the Kleenex on the exterior glass too. Since the exterior doesn't condense the aromatics from the interior, it only takes one cleaning and Kleenex buffing process. You'll be surprised how clear your glass becomes.
One final note. I can't stress strongly enough the advice given in both of the articles posted by ceningolmo: Do NOT, EVER, lay a cleaning, drying, or buffing towel/cloth down for any reason while working. Keep it in your hand until finished with it. Once put down, do not use it again until carefully laundered, and after drying, place them in a sealed plastic bag that will not allow any dust to get in and/or on the towels/cloths. Always keep your washing and polishing towels/cloths seperate from all others. Wash them carefully and after rinsing, run them through another complete wash cycle with no soap to get ALL of the detergent out of the fabric. Do NOT use dryer sheets on your car care towels/cloths. Immeditately upon removal from the dryer, place them in sealed plastic bags to prevent them from picking up dust, which is abrasive and WILL scratch the paint. Also be VERY careful to segregate towels/cloths used for the bumpers, rocker panels, and other areas that may have gritty dirt on them, and when cleaning these areas, replace the towels/cloths frequently to prevent dragging grit onto painted or plated areas and scratching them. Wash and dry them separately from the other cleaning towels/cloths.
