car makes a turbo noise afta i hit 3 grand??
DanMathers1
I'd guess it was the intake because I had the exact same problem on my old 240, unfortunatley I sold that one and never got around to fixing it, but I tested it once by taking out the air filter and it stopped whistling, give that a try its the easiest test. Just don't leave it out too long otherwise you'll end up sucking **** into your engine, not good.
xxtrizz
Car: Cars, computers
Ok I was part of that old A/C thread long time ago basically if it is your A/C system its your clutch on the compressor engaging and then disengaging. If it is your A/C system you would feel a slight thump in your accelerator when it makes that noise. But mine does sound like a BOV I was freakin out thought it was something serious but it was the A/C compressor clutch.
dbhittin
i have the same problem, and its the alt belt. But i cant hear it anymore cause my lifters are going crazy and my car sounds like an expresso maker cause the flywheel? or somethin is going out and its loud as hell when i let off the clutch.
Toad[^_^]
Vacuum leak
Supafly
midget in the trunk screaming to get out?
nab911
Car: 93 Nissan 240SX SE
Wow not sure if you guys fixed the problem yet but another thing is (hold on to you hats) your speaker grounds. If you have a bad groun on normal in car speakers, it will whine as you rev up, getting louder and louder. Its badass for a bit but then you like wtf?! Yours sounds a bit different but its possible.
evotech240sx
Car: 92 240sx fastback
u know, i have that sound too on my car. i just had a new ka24de put into a 92. and i checked all the lines i have, it cannot my intake. cause i have the injen cold air intake. which i can switched to short ram to check if it did the same thing as well. (which it did). my homies and i just guessed that it might be something witht eh pulleys or the belt. thats the only thing we can come up with. it sounds kool though i'll tell you what. when i roll out with my boys. they tell me that it sounds like i have a super charger or something like that.
civics91
Car: cars,cars,cars
zip ties on the drive shaft
2Fast240sx
Car: s13 coupe
this is happening to me too. when i first start the engine, theres no whistling, but when it gets to its normal temperature, there it is. i also get a ratling noise, and it gets louder in higher rpm.
navysnail
just remember that some filters can be louder than the engine as it reves. if it does it in all gears, then it's engine related, if only in a certan gear, then tire/wind/speed related.
2fast240sx, is it possibly coming from your transmission?
2Fast240sx
Car: s13 coupe
240kid wrote:just remember that some filters can be louder than the engine as it reves. if it does it in all gears, then it's engine related, if only in a certan gear, then tire/wind/speed related.
i think it happens in all gears. mostly you can hear it when i accelerate from a complete stop. how do i know if its coming from my transmission and how do i check that?
navysnail
it will be hard to listen while accelerating unless you put it on cruise and stick your head out the door, lol. seriously though, have you tried changing trany fluid recently(i would use redline mt-90) and it sounds to me like it may be the intake. do you have any kind of aftermarket/performance intake?
Bio_Hazard
Car: a crushed 1990 240sx
i had the same prob with mine and befor i replaced my exhaust and header, and after looking at my stock exaust manifold i found a 2 inch long crack on the under side, after words it went away.
2Fast240sx
Car: s13 coupe
ive tried to accelerate whil sticking my head out the window. lol. after a certain rpm, the whistling goes away. ive got a k&n filtercharger.
FDAPolice
Car: cars
could the noise be coming from the stupid loud *** fan connected to the engine?
2Fast240sx
Car: s13 coupe
ive got it. after driving around my neighborhood while sticking my head out of the window to listen for where the noise is coming from, i figured out that it was coming from underneath the car. i decided to park my car in my driveway and rev the engine while looking underneath the car. i realized that the rattling is coming from my exhaust. it is coming directly from the cat converter. i think maybe its the heat shield or something. i also think that this is where the whistling noise is coming from.
navysnail
i just took my heat shield off because it is rusted to hell. had to cut it off with a tourch. it still rattles a little, maby the insides of my cat are falling apart. it still passed emissions though, so i'm not gona mess with it.the k&n filtercharger will make the whistling sound, try revving the engine with the hood open, you will hear the filter, but i dont know why it cuts out after a certain rpm. maby its coming from another place. does it hapen at WOT?
2Fast240sx
Car: s13 coupe
i think im just going to end up buying a new converter from catco. yes the k&n makes a whistling noise but its not very loud. i was wondering what do you mean by WOT?
navysnail
wide open throttle, and before you buy a new cat, remove the heat shield and if that still doesn't do it, inspect the cat first.
2Fast240sx
Car: s13 coupe
thanks for the advice.
navysnail
tell us what you find
DAN510
somthing else to consider....
If your cat is broken down internally, it might be restricting exhaust gases enough to cause a backpressure buildup that may be "blowing" out from your egr transducer line coming off the exhaust manifold. The size of that line could create a perfect whistle.
I see alot of the rubber hoses joining the line to the egr valve have rotted off.
something to check....
:ylsuper
