Qdemption »
https://forums.nicoclub.com/qdemption-u11533.html
Sun Mar 21, 2004 12:40 pm
Need some help.
I finally got my car back together....plenum job with all the hoses, 5 injectors replaced, did both of my valve covers, cleaning of TB EGR IAC and MAF.
What I thought started all this was a bad MAF connection, BTW.
Well I finally filled her up with fresh fluids and before I started it I pulled the injector fuse and fuel pump fuse to prime the oil pump (as suggested per Daedelus and Company from a previous post). Put the fuses back in, primed the fuel pump by turning to the key to ON position three times. Then I cranked it.
It didn't want to start, as expected. After she started and warmed up a bit I noticed some problems. First the check engine light came on. I could hear a hissing noise near the back of the plenum. And the idle was rough. It would not rev past 3000 RPM. In fact the same symptons of a bad MAF were still present.
Now I ran the ECU and got a code 55. I am not sure if that is right, I am going to try and check it again here in a minute.
When I would rev it, it seemed to kind of gurgle and then rev. Almost like a hesitation. It was fairly rough.
Also there was some smoke. From the exhaust a lot of white smoke, but also in the engine bay, smelled like oil. I just think it is from all the cleaners and what not used along the process and the car is just burning them off.
What do you guys think? I am stumped and very discouraged.
p.s. 92 Q45, 155K.... The car has a good amount of trouble starting, as well.
p.p.s new fuel pump as well, there is only 3 gallons of gas in there..... don't know if that matters or not, just thought I would add.
