I think where most are missing the point on the active is the every day driving experience is improved. The Q wasn't meant to be taken to the limit. A while back, my friend bought a Passport G timer and I tried it on my car to do some 0-60 runs. When your not timing yourself, it gives you real time G reading on acceleration, braking, and turning. During some semi spirited driving, I barely cracked .5Gs, so for most driving situations, the active fits the bill. Sure the standard Q has more grip, but how often are you going to be there in a 2 ton luxury sedan. I think an active system is essential in a car the size of the Q to not have boatloads of roll on you're average right hand turn in the city, while still remaining soft on the straightaway over potholes and bumps. As we know, the problem with the active system is the complexity, expense and weight. Hell, if Texasoil lived closer to me, I'd love to have an active Q, but I don't have the skills or the time to be pulling out accumulators, sending them to Texas and reinstalling them. If you start to stiffen up the standard Q with lower springs, rear sway bar and poly bushings, you get a sharper handling car, but a bit of a rattle box on the bumps. Hell, even my Q, when I added the rear sway bar, I notice the harshness over bumps with not much gains in the handling department.
I was on the Koni website the other day and I was reading about these new Koni FSD shocks that looked interesting.
http://www.koni.com/FSD/
The FDS stands for Frequency Selective Damping. They claim that by the frequency of the road, it adjusts the oil flow in the shock to adapt to driving condition. If this works, this would be great. You'll never see it for the G50, but I'll look into these when it's time to change the shocks in my E46.
Modified by louiegz at 12:27 PM 4/6/2006
