trick240SX,
The contact details I have for Courtney is (
[email protected] )
The base kit only adds 100HP, but I assume that more would be available with a larger supercharger, change in pulley, intercooler ect. The pictures of this kit look very neat.
It is an autorortor/opcon twin screw type supercharger that sits in the valley. See how you go with Courtney on fitting the largest Autorotor/opcon unit. If you don't have any joy, I can give you another contact will be able to help you size up the right size Autorotor/opcon unit to match your HP requirements.
SIJOKO
Was the driveshaft a two peice unit?
One of the very first modifications I made to the Q was to the exhaust system, from the headers back. The set up is similar to yours. What made a huge differenceto the exhaust was then adding headers.
Would you like a set of custom exhaust dynamics racing computer designed headers in Satin Ceramic with 1 5/8" Primaries, 2" Secondaries, 2 1/2" outlet with dyno test sheet, showing a 42HP rear wheel gain to a naturally aspirated VH45DE.
The stock headers are a lot more restrictive than everyone believes, and I am expecting to get some people disagreeing with me for making this statement.
As far as I know, no one else has made custom headers for the VH45DE and contary to everyones expectations, they proved to be one of the best HP / $ I have spent so far.
I really would go for Courtney's kit and if he does not have headers, add the ones I have reffered to above.
Have a closer look at the turbo set up as a turbo will come on efficent boost within a rev range that the VH45DE is already efficent.
Your right about the boost level, 7 is ok in my experiance. Go for an Aquamist injection system. It costs more but is the best one on the market.
Hope you don't mind me expressing my opinion, but hope it is of some use to you.
Regards
AGM
