Can you get 500 whp from a RB20det
TCS-240sx
Hi I am new here and new with a RB20, I will like to knowif 500 whp is reacheble with this engine and what would I need to get there.
By the way I will be using a Microtech Ecu.
dekand
Car: 1995 240sx SE
its obvious you are new, and the question is not can you get 500 out of an rb20 the question is why would you want to.
see its pretty simple, you want 500hp but you want it out of an rb20 that tells me you dont have a big budget otherwise you would go the easier and more sane route of an rb26dett instead of trying to push an rb20 to its limits ... the fact is, if you had the money to make 500hp out of an rb20 it would be an incredible waste of time because you could have had it easier safer and more reliably with an rb26dett for probably the same price.
next time use the search button... please
s13rb25
Car: 89 240
Agreed. search and form more realistic goals. anything is possible with the right amount of money but unless youve got a pile of it to waste other routes are easier and more reliable.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
300 shot of nitrous
TCS-240sx
yes I did search!!
Is that i got the car for a goodprice and the engine was included.
I was thinking since i already have the enginei should use it.
So what is the safest max hp for this engine.
Sorry to bother : (
TCS-240sx
By the way I read (dont remember were) that someone had reached 480-490 whp with stock internals, with min investments.
dekand
Car: 1995 240sx SE
well the real issue is, why do you even need 500hp... do you know how fast just 350 in a 240 is?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
TCS-240sx wrote:Hi I am new here and new with a RB20, I will like to knowif 500 whp is reacheble with this engine and what would I need to get there.
500hp your going to need some good sized injectors. I would run 660cc or 720cc. Cams would help and a good intakemanifold. A good turbo would be needed and a good exhaust manifold and exhaust system. LOTS of Dyno time. Might run into problems with the RB20 box, the Internet says it's not very strong. If you get to that level of HP with that transmission I wouldn't drive it like a honda and use a clutch that won't grip too much. If it dosen't grip too much you might not kill the transmission. It's going to take some cash to get to your goal since they aren't alot of cheap parts for the RB20.
S13Sil-line
Car: Full throttle-*** out sideways
I'm shooting for over 400whp in my 240 hatch. Orginally going for 325 but when I upgraded the turbo and bought a Greddy E-01 and E-Manage then noticed it came with the optional injector and ignition harnesses. I'll probably end up getting it down tuned, but good luck keeping 500 in control in that car.
wawazat8402
Car: 89 Sil80- RB25DET
I am not trying to be an *** but I think a lot of people like the the thought of big hp numbers til they actually try to take the car on the street. I know a guy with a 500 hp integra and the thought is awesome but in all reality it is pretty much just a dyno queen. He can post the numbers but it is not very practical.
Just my half assed opinion though.
themadscientist
TCS-240sx wrote:By the way I read (dont remember were) that someone had reached 480-490 whp with stock internals, with min investments.
myth, ain't happening. I have seen a few 400hp RB20s but they were minimum 2.2 overbores with all the fixins. IMO having played with them for a while you could get a reliable 300hp out of a 20 on the stock internals. You would need at least a head gasket and valvetrain; cams, lifters springs. This assumes a tight fresh engine and clean healthy oiling system. I have said it till I am blue in the face, THESE ARE USED MOTORS! Japanese people on average do not maintain their cars well, they beat the hell out of them and sell them after about 3-years. You ain't going to get 400hp on a used RB20 with stock guts much less 500hp. You hav ethe 20 so use it. check it's condition and tune it slowly and correctly and you will be pleased with it, it's a solid mill. I would draw a musclecar parralel with big blocks and small blocks. Man the 454 is just a beast and deserves it's props but the lil 350 can get it done too all day long and cheaper. You will have to play catchup but it is not useless effort if it meets your goals. If you want streetable 300hp the 20 will do it all-day-long. The 26 is already above 300 but a bird in the hand yknow.
TCS-240sx
Thanks for the info..I guess i will rethink my goals...Maybe 400 is more realistic.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Still keep in mind that for 400whp... you'll probably need ~450 at the crank. The only way you will get that out of a 20 is lots of boost and lots of revs. To give you an idea, I calculated the mass flow rate of a 2L @ 8250rpm at 20psi and it is about 37.5 LBS/Min.
So say that's about 390hp at the flywheel... you are still shy of your goal by about 60hp. Granted you can tweak this flow number with tuning and cams (by all means you will need cams to make solid power past 6100 going by the dyno graphs I've seen... since that's what I've heard the big restriction up top in R's is, and reading the graphs shows where). So, like the scientist said... headwork would be key for getting solid power past 300 whp since the motor is going to need to rev to make that kind of power. I also hear the hypereutectic pistons cause the rev limit to stay down due to mass... so keep that in mind for anything much over 8k.
The 20 is a rewarding motor... and I really enjoy mine to death. I went with it because I like them more than the 25 (a few tech reasons but more or less... just because...), and I'd rather have my Kei Office coilovers and my 20 vs. spending the $ on a 26 (even though I like that motor very much).
I'd say shoot for 300-375 for whp... due to the fact that more than likely you are going to have a very peaky motor with minor mods and 400whp.
Here's my $1.50 on the subject... hope it helps.
goofynick6
Car: 1995 S14.5 RB20DET
That guy Palmer WMD on here got 497 whp on his stock bottem end rb20...just need a big turbo and tuning..
rbsileighty
He was running a thicker headgasket and alcohol inj as well if I remember correctly... T04 with lots of lag... but also made lots of power like you said.
Modified by rbsileighty at 11:46 AM 12/4/2004
TCS-240sx
T
rbsileighty wrote:Still keep in mind that for 400whp... you'll probably need ~450 at the crank. The only way you will get that out of a 20 is lots of boost and lots of revs. To give you an idea, I calculated the mass flow rate of a 2L @ 8250rpm at 20psi and it is about 37.5 LBS/Min.
Thanks for the info
How much power are you making and what mods do you have?
rbsileighty
Glad I can help!
Eh... blown turbo pushing 5.8psi... once I rebuild my small T3/T4 or just buy another (about the same price these days)... I'll dyno and let you know.
TCS-240sx
Thanks any help or info will be greatfully appreciated
rbsileighty wrote:Glad I can help!
TCS-240sx
rbsileighty- can you send some pics of your car and engine. : ) [email protected]
rbsileighty
Click on the "New Platform" link below the pic in my signature for all of the pics I have on my car. I also have a video on the Multimedia forum as well. Good luck on your project!
TCS-240sx
Thw car is sweet, the instalation is veri nice.It really looks like it belongs there.So you made the mount yourself. How did you get around the sway bar?
rbsileighty
Thank you very much!
For the mounts... careful measurements... the stock swaybar fits just fine.
TCS-240sx
HMMM that is interesting, I heard that you could not fit the RB20 with the stock sway bar because the oil pan would hit it.
Can you take a picture of the bottom front and do you have pictures of the mounts before ou installed them?
lyon23
Car: 95 240sx
since he already has the motor in the car he doesnt' need to spend the money on trying to get one, I think this is a plus some have not taken into consideration...so all he has to do is get the parts and work done..think it will be better and cheaper than having to buy another motor swap it in and buy the remaning upgrades to get it there...then it's the other question on how reliable is goin to be...I don't know where people these days are thinking of just hp...I don't want a dyno queen I just want to run 12's at the 1/4 I don't even care if it is a 12.9999999999, but I'm not worried about hp I know I'm gonna need some tires and a somewhat stiff suspension(not blown shocks). I 'm goin to upgrade my turbo fuel system and tune it and see how it goes and that's it.
TCS-240sx
lyon23 wrote:since he already has the motor in the car he doesnt' need to spend the money on trying to get one, I think this is a plus some have not taken into consideration...so all he has to do is get the parts and work done..think it will be better and cheaper than having to buy another motor swap it in and buy the remaning upgrades to get it there...then it's the other question on how reliable is goin to be...I don't know where people these days are thinking of just hp...I don't want a dyno queen I just want to run 12's at the 1/4 I don't even care if it is a 12.9999999999, but I'm not worried about hp I know I'm gonna need some tires and a somewhat stiff suspension(not blown shocks). I 'm goin to upgrade my turbo fuel system and tune it and see how it goes and that's it.
Do you also have a RB20|?
rbsileighty
TCS-240sx wrote:HMMM that is interesting, I heard that you could not fit the RB20 with the stock sway bar because the oil pan would hit it.
With the mounts I made the swaybar fits... I know because I put it on with no problems. I will take a picture when I get home in about 2 weeks. Shoot me an email about that time and remind me to snap a shot.
No pics of the mounts before install... there is an ok pic of one mount in the link under the picture in my signature.
Yellow4g63
Either of the mount kits out for the RB20 will clear the sway bar. I have had top hat mounts and they cleared. So dose the Mckineny mounts.
lyon23
Car: 95 240sx
TCS yes I have an RB20 in my S14. everything stock except for the FMIC, filter and 3" ehxaust.
TCS-240sx
rbsileighty:
The car sound beautifull!!! It rocks!!
rbsileighty
Thanks, I never imagined I'd get the response I've gotten from this car... means a lot!
