The first time went did this turbo setup without transmission cooling, and the transmission dumped in 2 weeks. This time, we put in a massive transmission cooler that has been holding the boost fine for 2 months. Now, I know the tell tell signs that my transmission was about to go, from the last time I went through this. They have yet to raise their ugly head this time around
Importroller wrote:I found out this weekend that the belt wasnt the problem. An actuator or solenoid in the transmission couldnt handle the heat generated and caused it to fail. so with lower boost (3-5lbs) it should be ok on a stock transmission. To me, not really worth it on a a CVT car, I would rather have a manual and be able to boost up to 7-11lbs depending on tuning, and really enjoy the power of the turbo
Pressure solenoid inside the transmission gave out. Overheated, and melted. The stock CVT transmission temps operate around 180-220 degrees. With the turbo, ours got over 260 degrees, and grenaded. This time around we installed temp gauges in the CVT fluid line, after the transmission cooler, and temps stay between 120 and 160 degrees at all times.
Also, the stock Altima Coupes' manual transmission won't handle the torque amounts over 8 psi. It unlocks itself and throws the car into neutral, if it feels this over torque condition.
