What BTU Rating is yours?adidas2go wrote:Well, If you look at my signature, you'll see the STILLEN front fascia. We mounted the cooler right behind the top grill. Its a B&M transmission cooler.
Post by blackedoutsedan » https://forums.nicoclub.com/blackedoutsedan-u191979.html Tue Jun 19, 2012 9:07 am
Post by sstroudwku » https://forums.nicoclub.com/sstroudwku-u211425.html Sat Oct 27, 2012 7:30 pm
You are very wrong my friend. The 2.5L uses a steel mesh belt, where the 3.5L uses a chain. The 2.5L REOFO9/10 are the ones that are mainly replaced. I have personally done 9 in the last 6 months. The 2.5 version is completely redesigned for 2013 and the warranty has been reduced back to standard powertrain 5/60 so far. The 10/120 ends with the 2012 model year.marlin29311 wrote:the CVT is a CVT - there is no difference between the 2.5 CVT and the 3.5 CVT except for the final drive ratio...
Return to “4th Generation Altima Sedan (2007-2012)”
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
