Can't Wait!!!!
tamdo714
Car: 240sx
i just ordered my Spl Rucas and some Hawk Hps Brake pads. I ordered them this morning and they are already shipping out!!! that's fast service!! A+ for spl and this isn't the first time i ordered from them. I highly recommend Spl parts!!!! Planning to install my Rucas, Slotted and Drilled Rotors and Hawk pads on friday and get an alignment on saturday! can't wait. So far my suspension set up is Spl subframe spacers (way worth it), Stance Coilovers, Cusco front and rear strut bars w/ rear triangle bar, Spl Rucas. Next i am getting is tie rods because my steering wheel feels loose and i heard new ones will do the trick and i plan on getting some Spl tie rods also what do you guys recommend?
94_240sx
Car: 94_240SX
Dang!! Sounds awsome. Can't beat $9 shipping from SPL no matter how heavy your package is and prompt email updates.
SPL Tension Rod v2Whiteline sway barsSPL Sway bar end linkNismo power braceCircuit Sports trunk strut bar
Have you done z32 brake upgrade?Your car will outhandle most cars on the street, man. Can't wait to complete my suspension upgrade. I have Stance GR+ Pros and SPL RUCAs too.
tamdo714
Car: 240sx
i haven't done the z32 brake kit yet. i just got the rotors/pads for now then i'll be on my quest to look for a whole set haha.
94_240sx
Car: 94_240SX
z32 brake upgrade is currently I'm working on.
tamdo714
Car: 240sx
what year and model has the 30mm ones? i'm either going to do the z32 brakes, or go all out and save up for some big brake kit. like the wilwood ones or rotoras or get the 30mm caliper and get the 350z front brake kit adapter thingy. how much is the swap costing you?
94_240sx
Car: 94_240SX
tamdo714 wrote:what year and model has the 30mm ones? i'm either going to do the z32 brakes, or go all out and save up for some big brake kit. like the wilwood ones or rotoras or get the 30mm caliper and get the 350z front brake kit adapter thingy. how much is the swap costing you?
I got 30mm aluminum for the front. $350 for all 4 calipers and $151 for the powder coating. My calipers are all in good codition and front left is a brand new. I need like 3-4 months to save up some money and finish the upgrade. I still have to get rear e-brake parts, ss brake lines, pads, rotors and master cylinder...etc. This is my current status.
zerothread/211697
Aftermarket big brake kit usually costs $2000+ easy, and I think it's overkill. You better consider 30mm big brake conversion...
tamdo714
Car: 240sx
those calipers look great man! nice write up also definaltey going to use it if i get the calipers.
