How To: Rebuliding Z32 calipers
94_240sx
Car: 94_240SX
Here we go guys. I did it over the weekend. I have 30mm aluminum calipers. Somehow I ended up with brand new caliper for the driver's side and used one for the passenger side. This is a picture of used one.
Modified by 94_240sx at 12:19 PM 11/27/2006
94_240sx
Car: 94_240SX
Remove clip from 2 pins in the back. Pins that are holding pads will slide out from the front.
94_240sx
Car: 94_240SX
Pads, clips and pins will come out easy and they will look like this.
94_240sx
Car: 94_240SX
If you just want to replace worn out or torn boots, you don't need to go further. Just remove boots, clean up and reinstall new boots, clips and pins that are included in most rebuilding kit.
If you want to powder coat your calipers, move on!!! I used breaker bar to remove big 4 bolts in the back. I stepped on the caliper and did this.They were bolted on pretty tight.
94_240sx
Car: 94_240SX
Then remove 'O' clips and rubber boots that protect the pistons. You will also see 2 small 'O' rings between two halves. Everything's out except pistons in below picture.
94_240sx
Car: 94_240SX
Now, it's time to remove the pistons. I spoke with 4 different powder coating shops and all of them asked me to take the pistons out, so I can tell they don't want to powder coat calipers with pistons in.Front half has 2 holes and the back has 3 holes. One on the back is for the brake line. You block holes and blow air in using air compressor. I used hand held 2HP compressor and it worked just fine. Get a trash can and put some newspaper and towel, so piston won't get damaged. They will come out loud and fast.
94_240sx
Car: 94_240SX
****Watch out for knuckles****
One piston will come out first, so use vice to hold that one and pop the other one. You really have to be careful here. You don't want to get hurt.
94_240sx
Car: 94_240SX
Picture of back half. There are rubber seals in the middle of the cylinders, so don't forget to take them out. Be carefull and don't make any scratches on the cylinder wall.
94_240sx
Car: 94_240SX
I cleaned them up really good and shipped these 8 pieces to powder coating shop in NJ.
94_240sx
Car: 94_240SX
Came back like this one week later.
94_240sx
Car: 94_240SX
This is the kit that I got from Courtesy Nissan. This kit should be universial for all z32 front calipers. I had a used set of rear calipers, but they were in very good condition, so I didn't buy a kit for the rear.
94_240sx
Car: 94_240SX
New pistons, seals, boots, clips and 'O' rings...
94_240sx
Car: 94_240SX
This is the seal that goes in the middle of the cylinder.
94_240sx
Car: 94_240SX
Push the pistons back in like this.
94_240sx
Car: 94_240SX
Put small 'O' rings between 2 halves. Okay, here's the deal. These small 'O' rings were not included in the kit. I saw someone bought them from ACE Hardware store though. I just reused old ones. They seemed to be okay. You need to lubricate all the rubber parts BTW.
94_240sx
Car: 94_240SX
Install new rubber boots, big 'O' clips and 4 bolts to complete.
94_240sx
Car: 94_240SX
I asked power coating shop to shave off NISSAN logos and they came out really nice. I'm going to buy Hawk pads later, so my calipers stay this way for now.
ILikeMy240sx
Car: SR Power
This is an AWESOME WRITE UP!!!!
Nice job!
94_240sx
Car: 94_240SX
ILikeMy240sx wrote:This is an AWESOME WRITE UP!!!!
Nice job!
Thanks man. Please feel free to ask any questions.
Bumnah
Car: 1992 240SX, black. Bone stock.
# to the powder coating shop, and price please.
those look nice.
94_240sx
Car: 94_240SX
Bumnah wrote:# to the powder coating shop, and price please.
those look nice.
This is the place.
http://www.trgcoating.com
He charges $35 for each caliper, so I paid $140 for all 4 corners plus shipping. I used DHL Ground, and it was $11 from TX to NJ. I accidently hit one of the calipers with a tool and it didn't leave a single scratch or scar. Very strong finish and should last for a while. Other local shops were not familair with z32 calipers, so I didn't hesitate send them to trgcoating. He's very familiar with Nissan stuff.
whitetshirtguy
Car: 95 nissan 240
how much did the rebuild kit cost i just need it for the front but yours look awsome and great write up and good pics
EW
Car: 95 S14
98 Cobra
06 F150 supercrew
Nice write up.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
What is the torque spec on the four connecting bolts that hold the two halves of the caliper together?
Article-worthy!
Let me know what you want your "custom title" to be!
zenkii
Car: 95 240sx
nice write up
gabossie
Car: Your mom
Great write up! I need to rebuild my calipers and paint/powdercoat them black.
94_240sx
Car: 94_240SX
whitetshirtguy wrote:how much did the rebuild kit cost i just need it for the front but yours look awsome and great write up and good pics
Thanks!!
Here's the seal kit(41120-30P25). It's only $30.44. Pins, clips and pin clips are like $5-10 for each or something like that.http://www.courtesyparts.com/M..._Code=
You can get them from PDM too, but I found Courtesy is cheaper. PDM charges $43.09 for the front seal kit which is 41120-30P25. http://www.pdm-racing.com/products/brakesz32.html
94_240sx
Car: 94_240SX
AmoebAssassin wrote:What is the torque spec on the four connecting bolts that hold the two halves of the caliper together?
Very sharp!!! I don't know. I just torqued pretty good. Besides, I don't think you can torque them right on the ground. I don't think they will leak though. Small 'O' rings should be able to manage the pressure.
whitetshirtguy
Car: 95 nissan 240
thank you and again great write up and they look awsome i wnat to see them on the car
