radianation wrote:Ok. I've made a post on the AEM forum as well, but here are the parts that I want to clarify about setting the base timing on the AEM/RB:
1. I have not done anything physically to the CAS to adjust timing. It's dynamic and the AEM just syncs with it, right?
2. I've adjusted the timing coarse/fine with the AEM and used a timing light, but when I did this I did not temporarily 0 out my timing map so I think it was skewed.
My question is, when using the timing light and adjusting the coarse/fine on the AEM it says to make them match, but I wasn't able to make them match. I just adjusted the AEM so that the timing light showed the marks lined up at 15 degrees. =/
okay first you dont have to touch the CAS and here is an "easy way to sync the timing"
1. hook up timing light2. go to the ecu set up > set timing blah blah blah3. put a value at the "fixed timing" section (i entered "10" degrees)4. check your timing with the timing light and make sure its the same value you put in under fixed timing5. if it is not then use the advance/retard buttons to get it to the same value (10 degrees).6. once you match the fixed value on the aem ems and the value on the timing light then your done.
hope this helps, im also using aem ems so if you have anymore question then feel free to ask me. i know that aem ems is a pain in the butt sometimes.
