I have a fix for this exact problem.95ka24de_zenki wrote:come on ppls , i need helps
Man I was worried there for a second too...95ka24de_zenki wrote: My turbo is a t3 and my manifold has the holes for a t3 and a t4. So I plan on taking the t4 part of the angle piece that I ordered, attaching that to my manifold, and will bolt my turbo to the other end, which will be the t3 flange. BTW, does anyone know where I can get the bolts that are used for attaching the turbo to the manifold, I don't know what they are called
Best bet is to lie to us and say the car was stolen otherwise...95ka24de_zenki wrote:I'm not that stupid at least I think I'm not
That is definitely a possibility. I simple heat shield should protect the BMC but won't help with under hood temps.AZhitman wrote:I foresee hood clearance issues coming.
Also, how are you shielding the BMC from heat?
The bottom mount SSAC manifold is decent. It's been proven now to not crack over many miles and several years. The top mount sucks in general. The waste gate flange is poorly designed, not large enough and the collector is awful. Now I know we're talking about something that's under 200 bucks...so I'll just stop.AZhitman wrote:ebay manifolds = garbage.
Time to take it to a welder and have it chopped down and re-welded.
AND there's the rub. First things first...WD is always right95ka24de_zenki wrote: As for what WD said, I don't think that will give me enough clearance.
I know, but I had to jack up the driver's side of the motor like almost 3" before it would fit, and that was with the brake line off. Don't get me wrong, I really appreciate everyones help. If it wasn't for you guys, I wouldn't have been able to do alot of stuff, so thanksWDRacing wrote:The mod I'm talking about was done to a S14 using the same manifold with a T3/T4 turbo.
Just saying it's easy enough to try. Unbolt the motor, insert ANY available spacer, lay the motor back in, then see if it fits. Take me like 5 minutes maybe...
AZhitman wrote:Wow.
Link to the auction so we can rip on this company's crappy product please?
Pisses me off...
I don't have anything bad to say eBay. You can't blame eBay because of some bad sellers. This is the first time that I have had any problems with stuff off of eBay. Unlike you, I haven't HALFASSED anything, nor do I plan to.kouki_hmongster wrote:First thing, you just wasted your money on egay crappp! this is why people should read the stickies first before they purchase their stuff. second, fuuuCKK all those company who are making stuff for cheap that doesnt even work or fit. third, you're still screwed for even thinkin about buyin ebay manifold, unless if it's the bottommount which is proven to work but still s***ttty. fourth, let this be a lesson and go buy a log manifold from JGS which is proven to work for a decent price.
i wouldnt even try to raise the motor at this point. i understand we're all on a budget, but there are some stuff you cant halfass. either payup or dont even turbo.
sorry for being a d!ck, just that i halfassed before and blew a motor and something tells me that you're probably going to halfass somewhere.
