95ka24de_zenki wrote: I'm not sure how I am suppose to put my bung on my oil pan for my drain line. I planned on taking off the oil pan and then put the bung on but there was no way for me to get the oil pan off. Some of the bolts were not accessible. Is there another way to do this?
loosen up the motor mounts, use a car jack to lift the transmission bellhousing next to the oilpan. move the sway bar in the front down(dont have to take it off completely). unbolt the oil pan, there should be three bolts holding the oil pickup stick two in the front and one 10mm on the driverside. hope this helps.
