Can double the right amount of engine oil damage anything?
IanW
My daughter just moved at short notice from Dallas to a new job in Los Angeles. I flew from home in Honolulu to Dallas to clear out her apartment, load up her '95 Q45 to the rafters with all her belongings, and drive it the 1450 miles to the West Coast. What a joy the drive was. The Q, with slightly elevated tire pressures, handled wonderfully. I never once twisted or squirmed because of any aches from the long hours of driving. It was just so very comfortable. The Q, even with a ton of extra weight, returned exactly 25mpg.That's the good news. After I had returned to Hawaii, the Q was taken for emissions testing for California registration. No problem. Next door to the testing place was an EZLube station. So it seemed like a good idea to my daughter to kill two birds... and get an oil change. Driving out of the EZLube, she found the car could hardly move, and could only judder along slowly. She drove round the block and went back to speak to the EZLube manager. "We're not mechanics" was his response, and with that she was dismissed. She carefully and very, very slowly drove to the mechanic recommended by her new landlord. Guess what was found?The EZLube had put in a full complement of engine oil without draining any of the old. A claim is being filed with EZLube for the immediate costs, but what might be the repercussions in the future of having driven the car a few miles with a double load of engine oil ? From what I've been told, the car, with the right amount of engine oil of course, seems now to be running OK.
Rex
Car: None
Here's what info I could find from a quick little search
zerothread?id=72192
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
If we're talking like 2-3 (5 TOPS) miles that she drove very gently, i doubt any damage was done..... As long as its now fixed
BY the way, glad to see your still posting here Ian.... How are you doing????
Q451990
I would make sure that everything is well documented in case there's something that can be attributed to it later. I honestly can't imagine what 12qts of oil in that engine would do... can't be good though.
Heath
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
The crank splashes the oil up onto the cylinder wall, and the barrel shaped pistons can be forced down onto the oil forcing the cylinder walls to crack, or the piston to break off at the skirt. OUCH !!
Great analogy: Like shooting a gun with an obstruction in the barrel, except the bullet is solid/not a piston!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Well, I certainly hope this little oversight has been corrected.
Like Squee says, the repercussions can be quite damaging if driven far, hard or fast.
Don't trust your Q45 to someone who doesn't understand what it is and how it works.
xsblacksx
i thought oil squirters stream oil onto the cyliner walls constantly
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
xsblacksx wrote:i thought oil squirters stream oil onto the cyliner walls constantly
What squirters?
zerothread?id=111352
The engine is drowning, basically. When it happened to our Civic, it drove like crap, occasionally spewing smoke and losing a lot of power.
