CAN ANYONE HELP ME ON THIS
97HARDBODY
Car: 1997 nissa hardbody 1989 jeep cherokee
k i need to know a few things on the RB26DETT and RB25DET as in length width and height and what transmissions go with what if you can help plz do thanx
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
what I think he was asking in regards to the transmissions were if they're interchangable at all (i'm guessing).
If so, all RB transmissions share the same bellhousing to block bolt pattern. (transmissions are not all the same)
The discussion of mix matching RB25 and RB26 engines and transmissions stem from simplicity of converting a RB26 to be used in a RWD platform.
As the RB26 comes with the AWD from factory, it's simply easier to switch to a RB25 RWD transmission which harnesses the same power capabilities as the AWD box found on the RB26.
For the overal dimentions of the motor and transmission, would require somone to bust out a measuring tape... anyone? I think it might of been covered once before as someone was looking to do a scaled model for a senior project and someone here supplied the dimentions. hmph
97HARDBODY
all right thanx and what about the size of the motors like length width and height
Coolwhip
Vendor
rough measurements (not exact)...
29 inches long, 28 inches wide, and iirc it was 22 inches tall from rocker to shallow part of the oil pan.
I'll measure a motor again tomorrow.
97HARDBODY
sweet thanx
neonbomb
Hey OP
you =
placham
Car: 1992 Geo Prizm (4AFE)---Gone
1990 Nissan 240sx Coupe (RB20DET powered),
1994 Toyota Celica GT (3SGTE swapped), 1995 Nissan 240sx KA24DE,
2011 Nissan Sentra SER Spec-V
neonbomb wrote:Hey OP
you =
WTF
I'm guessing his planing a swap into something other than S chassis, that's what he needs measurements
+1 ->Coolwhip ;-)
black240jl
Car: black 240sx
im guessing hes puttin an rb in a hardbody?, they have kas stock so rbs should fit fine..
Coolwhip
Vendor
if it's going into a Truck then talk to Kevwa and get familiar with his thread as he's the one to talk to when it comes to Trucks + RB = Pure Awesomeness!
zerothread/310951
