Post by blacksrjdm » https://forums.nicoclub.com/blacksrjdm-u52167.html Mon Oct 27, 2008 10:05 am
Post by sldewyz » https://forums.nicoclub.com/sldewyz-u70788.html Mon Oct 27, 2008 10:12 am
Post by 240_SeX » https://forums.nicoclub.com/240-sex-u88915.html Mon Oct 27, 2008 11:12 am
Although you think you have magically sovled your problem, i highly doubt that p/s fluid solved a rotational vibration issue. The fluid does not "resist" movement, it aids in movement. your p/s pump provides hydraulic pressure that helps you turn wheel/rack.migsk8 wrote:bahah, ok well guess what guys. i forgot to tell you. i have no fluid in my power steering rack or any of my ps lines. it slowly leaks out. it took about 5 or 6 months to all leak out. the fluid has recently ran out. could that be it? sinse theres no liquid to resist. just a thought. i just put ps liquid in it and im about to take it for a drive. ill le you know how it turns out
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
