can air in my brake lines cause my front tires to shake ?
migsk8
Car: 240sx
sory hijacker but i refuse to post in the "suspension technical section" nobody even goes back there and its been 24 hours and nobody has said a single peep.
ok so my front tires shake at around 40 mph. i got my tires balanced 2 days ago and an alignment yesterday. my frotn wheel is bent a lil bit. but it balances out perfect so its not that. also i didn't tighten my rear calipers nipple all the way so a tiny bit of brake fluid has been leaking, whoch cause me to believe i might have air in the lines. the pedal feels fine tho. but i'll bleed it out anyways. what else could be wrong ?
Dattebayo
Your bent wheel is the problem. Balancing a bent wheel is only a crutch, it only allows you to run it in the short term. It doesn't solve the wobble problem.
Also, depending on how hard you hit, the axle, knuckle or any of the suspension could be helping that wobble even more.
So get a new wheel and check. Most likely, that's it.
/thread
migsk8
Car: 240sx
well then how was the tech able to balance out the tire ?
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
migsk8 wrote:well then how was the tech able to balance out the tire ?
It may balance out but that doesnt fix the BEND IN THE WHEEL. That only balances the assembly on a free wheeling tire balancer...In order to fix a bent wheel it must be bent back to how it originally was...or buy a new one. Makes a lot of sense that a bent wheel will cause a vibration.
And as for the apology... I'm sure the reason that no one posted in the suspension technical section is because you answered your own question, but then disreguarded the problem in the same post by saying that the bent wheel isnt the problem...it is...and it will be until u replace it.
You may have also shifted a belt on the tire. I would return to the shop that balanced the wheels and ask them why it is shaking and have them check out the front end, and hell, u may have even lost a wheel weight since they balanced them and that could be causing it. If you dont know, take it to someone that does.
Dattebayo
I told you, balancing a bent wheel is only a crutch. You can only use the wheel at low speeds! DO you think I make this crap up or what?
Dittoz7
Car: 1997 2f0WtY SE!
Does It Spin The Tire To 40mph Rpms?
sldewyz
Car: 97' Danger Ranger
when u balance a bent wheel it only finds the best point to balance it. alot of the times you cant balance it out to zeroes on each side, they just get it as close to 0.00 as they can. either send it out to get fixed or buy another one. if you leave it on too long it will eventually affect your suspension in that corner. so fix it and see if the problem goes away.
migsk8
Car: 240sx
the thing is that it only happens sometimes. not all the times. you guys are thinking that its none stop. no. it only happens once in a lil bit. so i still dont think its the rim. im glad how i ask a question and nobody still answers it. remember guys i asked about the brake fluid not the bent wheel
Dattebayo
Seriously, we didn't answer your question about brake fluid because it is ridiculous.
Its going to be the bent wheel.
574-240sx
Car: Nissans, Toyotas, Subaru
Dattebayo wrote:Seriously, we didn't answer your question about brake fluid because it is ridiculous.
I have dealt with this 3 times in the last 2 weeks with customers cars.
blacksrjdm
migsk8 wrote:the thing is that it only happens sometimes. not all the times. you guys are thinking that its none stop. no. it only happens once in a lil bit. so i still dont think its the rim. im glad how i ask a question and nobody still answers it. remember guys i asked about the brake fluid not the bent wheel
I think I answered the question pretty clearly...If you cant figure it out take it to someone that does. If you think a shake in the front end has something to do with a rear caliper bleader, then sir you are completely lost. If you think it does then check the bleeders, then blead the system and if it doesnt fix it then we were right about the bent wheel. If you blead the system and it fixes it then you were right. But argueing about it online...isnt gonna fix your car or make you feel any better about it.
If you dont know how to fix it...THEN TAKE IT TO SOMEONE THAT DOES. BUT DONT ASK STUPID QUESTIONS ON THIS SITE AND EXPECT NOT TO RECIEVE AN EDUCATED ANSWER TO AN UNEDUCATED QUESTION.
sldewyz
we did answer your question. your original diagnosis could be wrong. you asked us to help and we are. if you want go ahead and bleed the brakes and see if were wrong. it wouldnt be a bad thing to do anyways but, i used to work at a tire store for almost a year. people came in with the same exact feeling, we replaced the wheel or sent it out to get fixed and viola! no more shaking/vibration. if there were air in ur lines it would only shake during braking. also since ur wheel is bent when you brake its going to put more force on ur wheel causing it to vibrate more because your putting more load on it slowing down because of the weight shift to the front.<-------run on sentence i kno
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
my dear god, I really hope this thread is a joke by the OP
prjktejvii
Car: 240SX, and a Civic TYPE R
Bro, you CAN, you can balance out a box on those things, but that doesnt mean you're good to go, trust me i work at a CORPORATE OWNED Tire Shop, and yeah there is a lot of BS being spit out by those guys at the front counter.
your problem is your bent wheel, get it fixed!
prjktejvii
Air in your brake system will only cause vibration when your BRAKES are used.
dickie
Car: Killer Turtle
PS:
moved to wheels, tires, brakes, suspension
refusing to abide by the nico policies voids your membership, btw.
migsk8
Car: 240sx
dude
d!ck wrote:PS:
nobody even goes back there, its wuite sad and lonely back there
dickie
Car: Killer Turtle
so youre going to help the situation by avoiding it too? thats illogical. ill get ask the wheel and tire mods to be more active.
Dattebayo
Tell the wheel and tire mods that you will put them in a tire and roll them down the interstate if they don't start moderatin' y0.
migsk8
Car: 240sx
bahah, ok well guess what guys. i forgot to tell you. i have no fluid in my power steering rack or any of my ps lines. it slowly leaks out. it took about 5 or 6 months to all leak out. the fluid has recently ran out. could that be it? sinse theres no liquid to resist. just a thought. i just put ps liquid in it and im about to take it for a drive. ill le you know how it turns out
blacksrjdm
Yo, dude, give it up...stop posting you fail...Have another blunt and go lay under your car for a while and maybe something will pop into your head...
migsk8
Car: 240sx
blacksrjdm wrote:Yo, dude, give it up...stop posting you fail...Have another blunt and go lay under your car for a while and maybe something will pop into your head...
hey guess what, i was right. there is no more vibration after i put the ps fluid in it. i win, you loose. go hit the bong loser
dickie
Car: Killer Turtle
lol.
blacksrjdm
So this thread was even more useless. Damn shame people are clueless. Aww man, I'm hi.
migsk8
Car: 240sx
blacksrjdm wrote:So this thread was even more useless. Damn shame people are clueless. Aww man, I'm hi.
what a sore loser. just give it up. you lost. get over it
blacksrjdm
Not to continue all day, but U lost because this was a pointless thread, and it could have been avoided by checking your ps fluid. So you loose, and you were wrong... fool.
sldewyz
so was the whole point of this thread to make u feel so smart and trying to make this a game on nico when u coulda just fixed the problem 5-6 months ago...makes u seem more stupid then we originally thought...
migsk8
Car: 240sx
blacksrjdm wrote:Not to continue all day, but U lost because this was a pointless thread, and it could have been avoided by checking your ps fluid. So you loose, and you were wrong... fool.
sike b1tch
blacksrjdm
sldewyz wrote:so was the whole point of this thread to make u feel so smart and trying to make this a game on nico when u coulda just fixed the problem 5-6 months ago...makes u seem more stupid then we originally thought...
My thoughts exactly... all could have been prevented with some regular maintenence that should be done anyway...But obviously some people just dont take care of their cars.
sldewyz
well anybody can miss a small leak. but its just pointless making it a stupid ordeal online only to make him a baller on the interwebz.....
