Chris69427 »
https://forums.nicoclub.com/chris69427-u981.html
Sun Sep 01, 2002 4:35 pm
Most people don't realize that an auto's torque converter unlike its manual counterpart (the clutch) actually multiplies torque a very small amount just like the gears in your rearend.
If the auto has a good TC matched to the engine's powerband (or torque-band, rather) it won't have that "lag" while shifting... add a shift improver kit and you'll chirp every single gear like a manual; and speaking of manuals you can also convert an automatic valvebody to full manual... which makes the only advantage to driving a manual the close ratio between the gears (less rpm drop in manual trannys), but factor in that no one can shift their manual as fast as the improved auto I described above, an automatic could whoop a manual!
Why do you think most drag racers run autos? I know a lot who run two speed powerglides, in fact; talk about rpm drop... These are sub 10 second cars, I'm talking about!
Later,
