A cool intake charge is good, but just remember, warmer air in the runners promotes a better mix of the atomized fuel. Too cool and you could end up with problems too.T45 wrote:Sweet, definately keep us informed. I'm thinking of insulating my intake mani when I drop another engine in. Maybe get a slightly cooler intake charge. Probably a waste of time but it couldn't hurt. I assume you're running full synthetic in everything? Have you pulled off all the vibration isolators off the trans mount and rear subframe? Few lbs to be lost there too. Awesome build, so jealous!
Show us the pictures of the pieces!SuperHatch wrote:The guys at M2 seem to think these cams should be good for ~30-50HP and another 2000RPM of useable power with a decent tune. We'll find out in the next month or so.
I'll post pics when I get the heads back from the machine shop...maxnix wrote:Show us the pictures of the pieces!
9400 rpm won't be kind to engine life!
Good luck! That's a lot of piston speed for that mass and rod strength.SuperHatch wrote: I plan on seeing what this will do at 8000-8500 now.
Pretty sorry cleaning job on your intakes!SuperHatch wrote:As promised, Got the heads back on Friday...
Don't you have like a "discolored shift knob" thread to post in or something?maxnix wrote:Pretty sorry cleaning job on your intakes!
I'd send them back.
Actually, whp dyno charts are the best way to see a power gain, since trap speeds are going to depend heavily on ambient temp, humidity, tire wear, track temp, how you drive, etcSuperHatch wrote:
Dyno charts? You won't see any. What you will see is the change in Trap speed from the stock setup. Thats a better indicator of power gained than any dyno.
We will agree to disagree on that one.PanzerAce wrote:Actually, whp dyno charts are the best way to see a power gain, since trap speeds are going to depend heavily on ambient temp, humidity, tire wear, track temp, how you drive, etc
I'm trying to be patient but I'm all like..giddy and stuffSuperHatch wrote:Didn't anyone ever learn to be patient?
I got one of the heads on Monday since we had a snow day and I had an hour or so of spare time. I'll be working on it again tomorrow afternoon and then again on Saturday. Hopefully I'll get it finished up on Saturday...
Nistune and a wideband...DJ Raijin wrote:How are you going to tune the thing then?
Why not?SuperHatch wrote:No, you can't ovalize the siamese heads to the same shape as the oval heads. You can make them oval though, but you have to oval the intake manifold too.
If you look at the siamese ports, the outside edges of the two circles are wider than the width of the oval port in the later heads. Yes, you can connect the two circles together, but if you try to use the late intake runner on it the resulting oval port on the head will be wider than the oval port on the runner by a substantial amount.Raxephon wrote:
Why not?
That statement can be quite misleading without the addition of details.
