Camber adjustment on Eibach springs? 2007 M45 sport.
KongzTT M45
Car: Have a 300zx twin turbo.
Have a 2007 M45 sport.
Honda CBR600rr..
F150 crew cab 5.4 lariat..
a few other things :)
06M4.5 wrote:Sounds like you have everything you need. :dblthumb:
pending on how many miles your M has you may want to check your swaybar links, fronts go bad as early as 30k miles. Cheap and very easy to install.
Also try to get an alignment 30 days or 1,000 miles after installation, this will allow the springs to settle. Make sure you have a full tank of gas when getting the ailgnment.
Good luck with the install, Freddie
Thanks!
I will post my experiences..
I also purchased kyb strut boots front and rear.. SB101 for both..
bicsintegra
Car: '06 Infiniti M35
'06 Infiniti G35 Sedan (daughter's car)
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
KongzTT M45 wrote:
bicsintegra wrote:i have the eibach pro kit on my 06 M35 and i also had the eibach control arms installed recently. it was not that expensive like 230 shipped from autoanything.com if you mention this forum you can get the same price or close to it i ordered my set 6-7 months ago. the camber is still not to spec but my tires do not look like a Honda civic now but i still rotate every 5k miles this will help with tire wear.
Why aren't they in spec? Eibach springs don't lower the car alot.. So the camber isn't very aggressive.. Is it just that you haven't had an alignment done yet?
What did you do for the rear?
the rear was not bad at all it was mostly the front. the shop that did my alignment I have been going to for 6 cars now and they always leave the front with a little camber not the Honda civic camber but a little lean in on the front tires.
