Camber Adjustment after Eibach Drop...
All things Altima Coupe.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Ok so i just had my car aligned... (in the shop my tech was arguing with another tech, over which they would prefer... some super DART or a 06 vette lol)....
Anyways the camber is off (probably why i dont rub, and im not so sure i want to correct it)...
I have attached the form he gave me... Im not really sure what it all means... but the top of my wheel is tilted too far tward the inside of the car
He essentially told me this will cause no issues other than tire wear.. but just an FYI for you guys... Same issues with others?
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
Just got mine aligned yesterday at Firestone... 169.99 with lifetime free alignments for the life of the vehicle!
And yes, he said that to correct it back to factory specs, we need a camber kit! Mine was/is off also, and so is everyone else's that has the Eibachs, whether they know it or not!
desertdragon
Car: 2008 Altima coupe 3.5 SE with CVT Winter Frost
rjdmmfl1 wrote:Just got mine aligned yesterday at Firestone... 169.99 with lifetime free alignments for the life of the vehicle!
I thought with Pro kit, you don't need camber kit.
mpbclutch33
Car: 2008 Altima Coupe 3.5L, 6-speed, Radiant Silver.
That was the word I heard too when the group buy was going on. WTF !!
cuzzbubba420
Car: 08 Altima 2.5 S w/ CVT
This blows, my main reason for buying the pro-kit was because it needed no camber adjustment. (I hope I don't get to look forward to going threw a s*** load of tires)
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
My mechanic mentioned something about my tires still getting about 30,000 miles with the springs and camber.
He also test drove the car and said he like it. Sweet
rjdmmfl1
I'll upload my alignment printout when I have a chance.. but it looks pretty much like LBC's
cuzzbubba420
My mechanic said the same thing and loved the way the car drove. I'm only at 80 miles after the drop so I'm waiting until 150 to get my alignment.
mhm1170
Car: 20008 Altima coupe
I talked to my local (bay area) speed shop today about dropping my A/C 3.5 with eibach springs and he also mentioned that a camber kit is needed. I did not agree with him because of what I read here on the forum, but he disagreed with me and said that he called eibach to confirm, and YES a camber kit is needed to do the job right. As for the labor...........4 hours to install the springs (1 hr each spring) I thought that was a bit high but he seemed to know about the camber kit needed, so I now trust them and will have them lower my A/C for me. He also mentioned that there will be no compression on my stock shocks/struts with the drop and he guarantees there work. Customer satisfaction!................. Yeh baby thats what I like. I also will have them install my Greddy Ti-c system as soon as more come into the country (6-8 weeks).
As far as alignment,...... no reason to wait................ eibach springs do not need time to settle/break in, once again this coming from my local speed shop.
Mike
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Guys, we have discussed this countless times. Get the kit if you want to conserve the tires to the greatest extent. However, with regular rotation, there will be no issues with the camber. The rear has a negative camber stock. Obviously the engineers saw a reason to give it that camber, and the eibach kit only enhances it a little. No reason to freak and panic over a half a degree in the rear.
mazda2005
Car: 2008 Altima Coupe 3.5 BLACK
Does a camber kit exist for an altima coupe? and if it does would someone be able to post a link or any recommendations.
Thanks
mcheddadi
Car: R8
screw the tires! I wanT 5 DEGREE NEGATIVE CAMPER ON THE 4 CORNERS
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
My cambers on all 4 corners are negative and its always good to have a little bit of negative camber. More tire contact on the road. However, the most important thing on the alignment is the toe. If that is out, you'll go thru tires like crazy.
cuzzbubba420
Sweet, I'm getting my alignment next weekend.
LongBeachCoupe
2005 Lexus RX
mhm1170 wrote:I talked to my local (bay area) speed shop today about dropping my A/C 3.5 with eibach springs and he also mentioned that a camber kit is needed. I did not agree with him because of what I read here on the forum, but he disagreed with me and said that he called eibach to confirm, and YES a camber kit is needed to do the job right. As for the labor...........4 hours to install the springs (1 hr each spring) I thought that was a bit high but he seemed to know about the camber kit needed, so I now trust them and will have them lower my A/C for me. He also mentioned that there will be no compression on my stock shocks/struts with the drop and he guarantees there work. Customer satisfaction!................. Yeh baby thats what I like. I also will have them install my Greddy Ti-c system as soon as more come into the country (6-8 weeks).
Mike
Mike... i dont know if id call them a "speed shop" if it takes 4 hours to install the springs... maybe a "scalp shop"... if they are charging you by the hour...
adidas2go
I think speed shop refers to, "speed" in a performance element rather than time
D-Roll
Car: 08 Nissan 350Z Touring Coupe
dangeris wrote:My cambers on all 4 corners are negative and its always good to have a little bit of negative camber. More tire contact on the road. However, the most important thing on the alignment is the toe. If that is out, you'll go thru tires like crazy.
A lil negative camber helps in cornering as well.
LongBeachCoupe
2005 Lexus RX
adidas2go wrote:I think speed shop refers to, "speed" in a performance element rather than time
Obviously thats what he meant lol... i just had to comment when they quoted him 4 hours to do the install... maybe they meant you would need to leave it there for 4 hours... but i cant see how it could take 4 hours to complete the job.
kyle@stillen
Excellent point!
A little bit of negative camber can make the car corner so much nicer. Basically when you load the car into a corner the tire flattens out and gets a wider contact patch. This helps out a lot with your grip and will solve any understeering problems you might have.
razah9
So you're saying no alignment is 'ok' or yes on the alignment &don't worry about the camber kit?
kyle@stillen
Definitely get an alignment but I wouldn't worry about the camber kit for now. If you experience excessive tire wear (which I doubt) then you'll want a camber kit.
LongBeachCoupe
2005 Lexus RX
ps the stealership will do your alngt free!
cuzzbubba420
yeah, and probably mark down in their computer you changed your suspension to!! VOID!
razah9
Firestone here I come.
mhm1170
I have called a few other places to have my eibach pro kit springs installed and they all seem to be between $400-550 includes alignment and camber kit. Everything is more expensive in the bay area, even at the gas pumps............. $3.85 gallon
Mike
mhm1170
longbeachcoupe, they say it takes about 1 hour for each spring to be installed............ They quoted me $500.00 to do the job........... includes labor, wheel alignment and camber kit. I already have the eibach pro kit. Looks like I will have them do the job........ next week.
Mike
niztec
Car: 2008 AlTIMA COUPE
mhm1170 wrote:I have called a few other places to have my eibach pro kit springs installed and they all seem to be between $400-550 includes alignment and camber kit. Everything is more expensive in the bay area, even at the gas pumps............. $3.85 gallon
Mike
dont worry man...here in hawaii gas is the same price...
GreyZone
Car: AC 3.5 SE 6MT Dazling White
correct me if Im wrong here...but isnt only the left rear out of adjustment? It looks like the other three tires are okay...
THis is of interest to me, as I have only installed the Ibach's spring on the front. SOme may remember I have wieighted the rear (180 lbs) and removed the RSB, becuase I like the handeling charachteristics of that set up much better...it looks the same as putting the springs in the rear, but I'll bet my rear camber is still okay, and it looks like my front camber should be also.
cuzzbubba420
Kyle, (or anyone) do you have any suggestions as to where I can get an alignment? I've tried Firestone but they are telling me they don't have specs on 08 models and they won't do it anyways since I've changed the suspension?
rjdmmfl1
cuzzbubba420 wrote:Kyle, (or anyone) do you have any suggestions as to where I can get an alignment? I've tried Firestone but they are telling me they don't have specs on 08 models and they won't do it anyways since I've changed the suspension?
I did notice that the printout on my alignment sheet said 2007 Altima... I heard that previously that a lot of companies didn't have the latest alignment info for the 2008 Altimas... but they did mine with the suspension change! And, Ican always go back and get it done for free... forever!!!! lol
