ace0073 »
https://forums.nicoclub.com/ace0073-u50339.html
Wed Jan 10, 2007 3:47 am
does anyone know good cam specs for a turbo KA? I have looked online a bit and i only get info on what 'stage' the cam is. What about actual numbers? In my case i plan to run a t3/t4, .70ar compressor, 63 exhaust. I want 400+ hp range with great top end. I am currently looking at a set of crower cams--no stage but here are the numbers i was given:duration:262 deg. int/exh,lift .397 int/exh,agressive but good idle. Any opinions on these specs or if i should go with a different grind for my needs?? any opinions are appreciated. also, on a totally diff note, who is in charge of deleting threads here??
