Cam Romour, is it true?
young-gunn
I've been told by different members that cam from a 91 240sx anre more agressive than that of a 92I also was told that 95 cams are even less agressive than an S13's cams.
Is any of this true? If so, could I put 91 cams into a 92 without damage?
Or better yet, could I put the 91 cams into a 95 for a bigger increase?
Just Curious.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Yes you can swap cams around to increase power. There is a thread flying around here somewhere detailing the cam swapping procedure, and what duration cams came in which motors.
young-gunn
I didnt see anything in the search I did earlier, does anyone know where this is?
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
Here's the thread.zerothread/152578
S13 cams are the same between all years regardless of what people say. 91,92,93 no year is better. The cams are the same! BUT the s13 cams do make a difference in an s14, or running 2 exhaust cams in an s13 etc.
The article details it and is quite long.
I personally run the 248+5/248 cam setup. 2 s13 exhaust cams, with the cam sprocket drilled out to advance the one on the intake by 5 degrees.
