ScottJackson wrote:Whoah! It's just my opinion that it's the most cost effective way to make power with this motor considering the cost of camshafts, intakes, etc.
Opinion != FactA set of camshafts are but four parts that need to be swapped out/in to an engine to radically change its dynamics and power output, and should cost under a grand. It's about the only thing on a NA motor that you can actually do to get this much of an effect. The price will be roughly the same as a very cheap turbo.
ScottJackson wrote: Why put twin turbos on the thing when a single will do a dandy job? Why pay so much for them? Why not a good Holset HX40 or similar sized Garrett (around 60-66mm) for $300 or less? That'll support 500-600hp.
Physically huge V8 engine, typically small engine bay + a big single turbo is a nightmare to set up. There's very little clearance around the motor as it is, especially in stock Q45s where they have ABS and AC and all the extras... just about every available gap in the engine bay is separated off by itself with something in the way.
Why pay so much for them ? That's just how much turbos tend to cost if you want to get a decent size & quality one that hasn't been raped... as I say, it doesn't pay to do things halfarsed. If you're buying a second hand turbo, you're not going to know if it needs rebuilding until you get it, which can cost ****loads more. For the price, brand new turbos are worth it.
ScottJackson wrote:The injectors will be required for the N/A setup too once you exceed a certain power level.
A good rough way to figure it out is CC per HP. The stock 370cc injectors should be just nearing their limits at over 400HP.
ScottJackson wrote:Those cheapy $250 air/air intercoolers on ebay have been proven to work quite well and are well built for their price.
I don't know too much about intercoolers, but US$250 on eBay is almost NZ$500 as I quoted... and if you settle for a cheapy, you can run the risk of getting something sh*t. But fair enough, purchase with some discretion of course! Deals do crop up.
ScottJackson wrote:A remote mount turbo would work just fine with the stock exhaust manifolds and piping. Yeah yeah, some people say they don't spool up well and that's true if you use a large turbine. The key to remote mounts is using a bit small turbine and a rather large wastegate.
True but where do you fit a remotely mounted turbo on a Q45? Not saying it can't be done, but again, space is a constraint. This also bumps up the cost of materials as you're going to need more piping to mount a turbo further away. Seems like a lot of hassle.
ScottJackson wrote:If you build your own water/meth injection setup for under $300, you can omit the intercooler AND the larger fuel injectors up to a point. It also allows much higher boost with stock compression. If you feel so inclined, check out the turbomustangs.com forums. There's guys who've built reliable complete turbo systems for under $1000 and are making over 500rwhp with them on what many import lovers would call archaic crappy stock Ford 302s. There's also the guy on that forum with the 3rd gen Fireturd with bone stock 2 bolt 350 that's making somewhere over 600rwhp, with the stock pathetic smogger heads.
Those are awesome results on some impressive machines. There are some very clever guys doing very clever things there, and probably quite cheap too. Here's the thing though... what's the reliability like on a mongrel setup like that ? Also, I don't expect that many Q owners to be so familiar with their cars and mechanical stuff that they can just jump in and build setups like that. Things like that take ages to figure out, troubleshoot, and get right. Many people do not want that.
ScottJackson wrote:Of course how you build power is up to you and I do love a high revving N/A V8 with decent cams, but I could make an $8000 price list in no time for a rather basic N/A VH build also. I'm not saying that the cams shouldn't be done and would be a waste of money. I'm just saying that I don't think it's the most budget conscious way of getting more power from this motor and it's good to keep in mind all the options when costs are being added and being compared to benefits.
What other mods can easily be done to gain a significant increase in power on an NA engine, apart from the cams? That's the thing... the VH was designed to produce a crapload more power for race use, and was dummied down to make it meet emissions requirements and NVH requirements for the luxury market it fits into. The cams are one of the biggest restricting factors in a VH making power, because there isn't much lift and the profiles are far from optimal. It's the key to these heads.
There are people here in NZ spending up to $60,000 on their VH engine, revving them over 9000rpm, and making over 500HP in NA form with very little head work. I've seen these engines and learnt a lot about their setups, and they're much simpler than you may be willing to believe. It's all in the valvetrain, and making them strong and balanced enough to take the punishment to put these numbers out.
I want it to be that for under a grand you can buy a set of cams that you literally spend only 2-3 hours swapping into your motor, and provided you set them properly, you should be able to turn the key and your car will be a hell of a lot angrier and faster with no hassle! You simply can't get over 400HP any easier than that. Boost requires mounting a turbo or supercharger somewhere, plumbing it all up, using an intercooler or aftercooler, probably an ECU retune, new injectors, etc etc... and it'd be so much hassle to use boost to make under 500HP that it becomes pointless.
Wild cams are the best cheap mod you can do to a VH to get over 400HP without ****ing around, and I'm going to prove it.
ScottJackson wrote:Just curious, why would you rather have a VH over a hemi any day? You're still talking about the new hemi, right? I know it's not really a hemi (good thing too as it would never pass emissions if it were), but I'm quite impressed with that motor, as I am the Chevy LSx. Supposedly Ford's new V8s will be pushrod again in 2009-2010.
Because a VH is the strongest factory V8 that I'm aware of by any manufacturer... on stock parts they're 9000rpm capable, 1000HP capable, and I can buy ten of them for the price of one new hemi.
I'm not saying there aren't better ways of making power... but look at what I'm offering. It's not a top shelf 700HP cam kit for your supercar/race car... it's a cheap, easy, bolt in cam upgrade to unlock quite a lot more power from your stock motor, and pretty much any Q owner armed with a FSM and a few tools is going to be able to install the upgrade on a sunny saturday or sunday.
