I couldnt tell you exactly what was wrong without seeing hearing driving the car. All I know is that if your car really is struggling as bad as you say it is, it is not because you simply changed from the factory airbox to a cone filter. I have installed intakes on more cars than I can count and the only time a problem arises is when something is unplugged and forgotten to be plugged back in or if something else was previously wrong.fiveliterbeater wrote:well, there is only one thing to unplug: the MAF meter.......and the motor has only 9k miles on it (was replaced under factory warranty) , i don't think plugs go bad after an intake swap.
Yes it would throw a code, but I have found that infiniti's CEL is VERY shy compared to the European cars I used to own. I had a plug go out on my M 3 days after I bought it and it threw no cel light, but drove like hell and sounded worse...fiveliterbeater wrote:well i decided to go with an un-oiled filter from AMSOIL. everything else just checks out fine. guess it's a mystery for now.ill be putting my old filter back on for now. as far as the MAF being dirty, would'nt the car throw a code if there was something wrong or if it was getting a false reading?
Really? I find it funny you buy into your way of thinking as well. Good thing my marketing ploy worked so well that way I could make so much money off of fiveliter - I'm rich!GJEMD wrote:To all you "modifiers". its time to realize to spend money on intakes and exhaust systems on the M 45 without making modifications to the computer chip is a fools errand. I find it funny that so many of you buy into such marketing nonsense and that some how the Nissan engineers some how don't get it.
All along it was the variable valve timing that has been holding the engine back from making power? Could you explain that a little bit more? Does the valve not open as far when you add an intake is that what is happening? Please tell us!!!GJEMD wrote:The M45 at least the 2003-04 were marketed as luxury "hot rods". There is this little issue between the intake and the exhaust its called VARIABLE VALVE timing. The MAF sends data to the commputer chip that then issues commands to the valve timing which essentially neutralizing most of the effort at changing air movement ie HP. Why don't you install a "tornado" while you're at it.
I sent you that email with the parts list from infinitipartsusa.com I'm thinking it was the turbo hose causing the turbulence or that the 2 pieces weren't perfectly parallel....possibly both even. There is no other real reason why it worked for me and not for you.fiveliterbeater wrote:i was thinking, was i supposed to glue the MAF housing that i cut away from the airbox to the adapter instead of using turbo hose? i only used about 2 inches of it to join the adaper to the piece that i had cut off. could that be the problem?
Modified by fiveliterbeater at 3:51 PM 3/30/2009
Nope not missing anything there - if anyone knows me I have extensive camshaft knowledge especially when we start discussing duration. Here's a short lesson that maybe you've missed before making your post. Adding duration generally increases flow for better high rpm power but makes for dirty emissions in the lower rpm range with poorer idle quality and drivability. This reason is why OE Manufactures use VVT, V-TEC, etc...to maintain emmision standards/better drivability at low rpm/low load conditions and durring the high load/high rpm situations where the emission laws don't apply can switch to a more aggresive cam profile/durration to gain engine output.GJEMD wrote:Lets see where do I start. We can agree the max valve lift is fixed by the cam lobe. The part you seem to be missing is the "duration" of valve lift.
Really? VVT stands for Variable Valve Timing - thanks captain obvious Actually it's a comprimise for drivability - just like the bud light commercials talking about drinkabilityGJEMD wrote:The DURATION is the VARIABLE with VVT engines. VVT is always set by the factory to be a compromise between performance,emissions,and efficiency.
Sorry, I have to disagree with you on this one. Per the FSM the VVT system is controlled by a solenoid actualted oil control valve. This valve is opperated with battery voltage via computer controlled duty cycle based on engine speed, throttle position, MAF, IAT, and a few other sensors. It opperated to a max of 70% duty cycle because if battery voltage were applied for longer than 5 seconds it would comprimise the reliability of the solenoid to actuate potentially damaging the unit. At 70% duty cycle the durration of the camshaft is advanced a predetermined amount set by the mechanical limits of the control unit and the camshaft profile which in turn increases the duration of the "camshafts" since there are 2 (one intake and one exhaust). The main point here is that the VVT is being actuated to it's fullest extent in stock trim giving the engine the full capability to make the most power on the stock camshaft profiles. The real gain from being able to tune the VVT with a programmer is to bring it in sooner enhancing mid range power production.Based on what your above statement that increaseing airflow to an engine will not increase engine output is inherently wrong because the engine is an air pump and the easier to get the air in and out - makes for a more efficient process and increasing efficiency will definitely increase the power making "potential" - given that you keep your air/fuel ratio and ignition timing in check. This is the basis for ECU reprogramming.GJEMD wrote:This VKE engine I'm sure is capable of 400 HP with a Chip to advance the timing and duration of valve open time with no intake or exhaust mods.. The timing is surely retarded for emmision reasons. No amount of air from an intake with a MAF will over power this computer module. Again Intake and exhaust mods without Computer modification is a FOOLS ERRAND
Yes, contact UpRev for a reprogram and contact several JDM companies (Impul, Mines, etc) to import a fully reprogrammed ECU.nadzak wrote:Is there anyone out there who can mod the computers for our M35's? Or better yet, is there anyone who sells new ones?
GJEMD wrote:I"m just quoting the FSM so if I'm wron so is the FSM. I don't try to make people believe ideas, just facts.ken in az wrote:The main point here is that the VVT is being actuated to it's fullest extent in stock trim giving the engine the full capability to make the most power on the stock camshaft profiles.
I believe this to be unsubstantiated. You want us to believe that Nissan/infiniti set the VVT to max actuation only to choke off the air flow with a restricted intake and exhaust system.It seems your arguing both ways. Most all commercially available VVT engines are not set at max actuation because of emissions. Retarding this VVT allows for complete burning of fuel and less emissions. If you reprogram the VVT and open up the intake and exhaust you will for sure maximize power and increase emissions and decrease fuel efficiency. And you should attempt to make your point with less drama. Its clear you don't like being challenged. Mr camshaft
Also our engine only controls the intake cam, the exhaust cam is fixed.
And emmisions are not recorded at full throttle so there would be no reson for the factory to tone down the power at WOT.
So you want less drama then maybe you shouldn't call people a fool in caps
lastly, just stop arguing with me and we'll get along just fine
Mine has the lip and it works fine...also I don't have a full exhaust, still on stock resonators and mufflers, and I got my results at the track before I did the X pipe.fiveliterbeater wrote:....hey you know what just dawned on me? i think the reason that i may be losing power is because i'm improving the intake while keeping the stock exhaust and the car may be losing power. keep in mind that i made the car a true dual and the exhaust flow has been slightly improved but i maintained the stock mufflers. oh and by the way, i redid the intake again and this time i glued the MAF tube to the adapter and i think it works cause the car seems to respond a little better than it used to with the stock airbox. only problem though is that the adapter is little "bigger" than the MAF tube, so when you look straight through them while they are glued together, u can see a "lip" all the way around on the inside. i'm going to take a dremel tool and sand down that lip so that it doesn't create any turbulence inside the intake.
The transmission TCU adjusts within 15 minutes of driving ... does not take too long fortunately!mcrews wrote:THe chips in these cars can 'learn' how you drive. I tend to drive for MPG so I am sure the chips (especially the trans chip) have made adjustments.
today is your lucky day - I'm not going to spend time to make you look like an idiot since my mother in law's house was broken into last night while she was still in it. Too pissed to do anything right nowGJEMD wrote:Still I think my car is exceptionally slow running a 14.7 at 96 stock and with a heat soaked intake it ran 14.6 at 97. I thought they were supposed to run closer to 14 flat and 100mph stock.
It was warmer out the last time out so technically I would need to calculate the air density to see really how effective the air intake was. either way I'm faster and it sounds really cool so I'm happy. Ken in AZ
Well the truth hurts. Your M is slower than stock 1/4 mile times submitted on this forum, but it sounds COOL so your happy.Yes I'm sure you've persuade no one of your FOOLS ERRAND
