CA21DET Build
tommey
Car: S13 ca18det
I like that photo too, if you look closely you can see the "alignment" of the head is off, this is because i am not using the RB bolts and not having the "centering plugs" or what you guys call them on.
Trying to get the timing components sorted now, then maybe i can go ahead with the fun part!
..Wich is machining and making everything work!
themadscientist
float_6969 wrote:Isn't "ain't wearing no" a double negative? :poke:
And you wonder why girls don't let you see up their ports. :slap:
float_6969
Touchè!
themadscientist
Or touche them.
tommey
Car: S13 ca18det
oh lawd :picard:
CA18_nut
Car: Nissan RS13 '91 Ca18det
cool build , show the sr crowd what a 2l ca can do ;)
datso
Car: datsun 1000
Hello Im new here and I keep searching for info into building a 2liter CA for quad injection for my datsun 1000 coupe.
Searching through the net there is info not featured completely in all the build ups together in one place therefore making it difficult to confidently build a CA20DE
Ive acquired a CD20 diesel crank for its full counterweights and wondering if Im stuck with trying to source CD20 conrods or could I use something else?
Ideally Id like a ca18det bottom end with the cd20 crank with longer 136mm conrods and 25mm comp height kawasaki high comp pistons I have laying around that will give me 1.545 rod stroke ratio but finding off the shelve 136mm rods is an issue.
The other options is to use a ca20e block as we cant source the cd20 here and run long rods and 85mm pistons but will have to drill and tap for larger head bolts and confused as to which pump I can use considering the cd20 is Heavy Duty version of a CA20 or a longer version of the CA18det but with bigger head studs?
Also can anyone give clear info on which off the shelve Belt to use? (some say daihatsu Charade GTti other Porsche, then Toyota then Honda its all too unclear)
regards, Datsun kb10 owner
float_6969
The CD20 crank won't turn in the CA18 or CA20 blocks. At all. In any way. You HAVE to use a CD20 block.
datso
Car: datsun 1000
We shall see when I test fit the crank in a ca20e block but have a feeling it might at worst just need some slight block clearance if any at all. The CD20 block is ideal though so beefy and well designed. There is supposely 5 or 6 all alloy prototypes from the cd20 that Nissan where playing with before they went to the sr20de due to the the noise of the cd20 block was like 3 decibels higher!
float_6969
Please LMK if it will spin in the CA20 crank. I put my CD20 crank in a CA20 block and it wouldn't work. If yours works, then I wasn't sold a CA20 block (it was a bare block, so I didn't have much reference, and I didn't have a CA18 block to compare it to) and I need to beat someones head in, LOL!!!
datso
Car: datsun 1000
will do! I have also a ca16de block which is the same as the ca18de but smaller bore.
Will do it by the end of next week when I get back to my workshop.
The ca20 block is stronger than most peeps think it has quite a lot of meat round the bores for bigger bores yet nothing beats the CD20 what a work of art.
I really look forward to the CD21DET tommey is building. I hope he goes 92mm stroke as thats what that wildcat quirky monster used in speedway and made 260hp at 7000rpm on methanol with an antiquted 2 valve jag hemi head.
tommey
Car: S13 ca18det
Im going 92 mm, i was really undecided about that for a while.
I see the Honda guys rev 9000 rpm with 84x92 without turbo`s.
Im running a PT6466 .82 and e85 and i would like to rev it as far as i need to make the most out of the turbo.
This project is still going on, i am just concentrating on getting my car and supporting mods around the engine finished.
Damn Norway and its salted roads!
Heres a new part made ready for the CD21 :
datso
Car: datsun 1000
very nice! I personally love to do the same using a T5 or T56 with close ratio gearset.
Just in case you missed it, seems dodge SRT late conrods have 53mm BE bore and thicker width BE and 151mm c-c might be a goer in H beams.
tommey
Car: S13 ca18det
New balancer bought.
Should make it easier to get the drysump fitted.
float_6969
I have their race balancer and it's great. If I had room for then one you bought, I would have used it instead.
tommey
Car: S13 ca18det
Why don't you have room for this one?
Should be about the same dimensions as the stock one?
My plan was to use the race version, but if I can use this one I don't need electric PS.
float_6969
I'm running a Liquid to Air intercooler. My intercooler sits between the radiator and the engine. With the electric fans it puts it far enough back there wasn't room for the stock crank pulley. Hence the race balancer. I'm working on the EHPS now. I do have enough room for one pulley though and was contemplating trying to make a serpentine setup to run the A/C and P/S, but I would have had to built a custom brackets for the pumps and so I decided to run a the race balancer, EHPS, and then have one pulley made for the A/C and make a bracket for the A/C.
tommey
Car: S13 ca18det
I see
Im going to either mount the trigger wheel at the back of the balancer, or remove the A/C pulley and mount it there like I had on the stock damper.
float_6969
not much clearance behind the pulley. How thick does the trigger wheel have to be?
tommey
Car: S13 ca18det
I don't know how thick it should be
My last one was 8mm and probably overkill.
float_6969
I ask because I noticed that my Mazdaspeed Protege has a trigger wheel setup the other day when I was replacing the timing belt. I was really surprised at how thin the trigger wheel was. I've never seen a trigger wheel that thin before, but if you're standalone can handle the signal, it could easily fit behind the stock pulley. IDK if it's a special pickup or not, but it made me wonder.
aintnobiscuit
holy bajeesus.... do want! I'm very interested in seeing this work.
datso
Car: datsun 1000
when you feel like Tarzan please weigh the block with main caps only no girdle.
The 140mm rods make sense now as pistons are diesel beef of course standard.
TheMAN
float_6969 wrote:I ask because I noticed that my Mazdaspeed Protege has a trigger wheel setup the other day when I was replacing the timing belt. I was really surprised at how thin the trigger wheel was. I've never seen a trigger wheel that thin before, but if you're standalone can handle the signal, it could easily fit behind the stock pulley. IDK if it's a special pickup or not, but it made me wonder.
lol you'll be surprised how most modern engines are that way now... they just work... hall effect FTW
the mazda BP has the trigger wheel sandwiched between its two piece crank pulley... it works very well, until some tool decided that they have to disassemble the crank pulley to remove it and forgets whcih way the trigger wheel goes on... motor runs poorly (very lean, shoots blue flames out the exhaust manifold) afterwards :rotfl
float_6969
Blue flames? Sounds like a Fast and Furious wet dream!
tommey
Car: S13 ca18det
Not much progress yet, still working on my chassis.
I have decided on rods at least, 150mm 4g63 rods with the 22mm wristpins.
Another nice feature is that the 4g63 engine uses 21mm wide bearings where the CA "only" has 19mm wide bearings.
On a 30mm compression height piston (stock ca) i could have had little over 151mm long rods but i will compensate with the pistons.
I even have a rod to show!
These will do for now, maybe Carillo next.
tommey
Car: S13 ca18det
Clutch and flywheel ready.
datso
Car: datsun 1000
Looking good Tommey, good choice for the rod
I personally thought the cd20 crank mains had
bigger journals more suited to Dodge 2.3 rods.
What did the Tilton unit set you back? Im liking
that more than the Ogura kit from Japan.
tommey
Car: S13 ca18det
The CD journals are bigger, but i will grind them down to CA/4g63 measurements anyway.
The Tilton set me back about $600, its the 2 plate "rally" type with the thick discs.
I like this clutch better than the japanese clutches because its much cheaper and very streetable, unlike the ORC ect.
It will also hold 1200nm.
datso
Car: datsun 1000
best choice, tilton have awesome and cheap replacement discs compared to overpriced Ogura ones
