ca19det
scorcher Imports
Car: s13 rb30/26dett
scorcher Imports
Last edited by scorcher Imports on Mon May 21, 2012 11:45 pm, edited 1 time in total.
scorcher Imports
scorcher Imports
scorcher Imports
News..
scorcher Imports
scorcher Imports
scorcher Imports
Last edited by scorcher Imports on Sat May 19, 2012 9:04 am, edited 2 times in total.
scorcher Imports
Need more heat wrap..
Last edited by scorcher Imports on Sat May 19, 2012 9:04 am, edited 1 time in total.
scorcher Imports
scorcher Imports
scorcher Imports
scorcher Imports
scorcher Imports
scorcher Imports
[youtube]http://www.youtube.com/watch?v=NZUbjPfPGYc[/youtube]
0.5bar owner test
cbh148
Car: 2000 Civic Si, 1993 240sx Hatch CA18
float_6969
nice!!! This is one of the better post's we've had in here in a while. Thanks for all the pics and vids!
blownhemi
Car: S13 200SX CA18DET HX35
Just a noob question, if I may. You have a caliper, and a bore gauge... why are you plastigauging as well?
scorcher Imports
I double check to prevent errors in the clearances.
Another pic.
themadscientist
Measure twice, cut once.
Packrat182
That's a nicely done swap you got there. ;)
themadscientist
I don't think it's a swap. He's in Europe and that is a four port head. They got the CA18 there.
scorcher Imports
TheMAN
very nice build... I noticed you are using an inline type nismo FPR... what's the reason? The SR20DET one bolts onto the stock fuel rail just fine!
mdb4879
Car: 1987 Nissan Pulsar SE (CA18DET)
1990 Nissan 240SX (KA24E)
1995 Acura Integra GSR
A couple questions if I may. When setting up the oil cooler, why didn't you also relocate the oil filter? I use to not think to much of oil filter relocation until I rebuilt the motor in my daily and I hate getting oil all over my nice clean, painted engine, bay, exhaust, etc. when I go to do an oil change.
Also, I haven't owned a RWD CA, but it seems to me like they tend to sit with the front a little higher than the rear of the motor. So why didn't you put the drain plug for the oil pan at the back so you could drain out the most oil rather than at the front? Was there just too much a space restriction because of the crossmember?
Oh, and you stole my idea of painting my valve covers white :biggrin: Speaking of which, I've heard white engine parts tend to "yellow" over time from heat and getting dirty. Have you noticed much of that on the valve covers? I once was thinking of painting an engine block white but have since been deterred for fear of it yellowing, and I've grown to like a more basic OEM style look of a black block.
TheMAN
it looks like he's running dual oil coolers instead... the stock water cooler plus the air cooler
datso
Car: datsun 1000
sounds like the 4 port head can flow plenty more than a ca18 can as the size of the ports are comparable to a porsche 3 litre 4 cyl engine.
float_6969
There isn't actually that much more port area on the 4 port head. I know it looks like it, but it's not. With a good intake manifold design, I think the 8 port could make as much power as the 4 port, and I'd be willing to bet that if the butterfly valve concept was integrated somehow, that it would have more area under the power curve than the 4 port.
datso
Car: datsun 1000
I agree but still think the 4 and 8 port heads have way more volume than required even with short rod stroke ratio they are massive ports.
float_6969
agreed!
