pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Tue Nov 09, 2004 1:51 pm
I believe he is getting a spark, as when he sprays "quick start" the car starts for a short period of time which indicates that there is a spark but no fuel.
You either have the injectors clogged(very common on these engines), or your fuel pump isn't turning on.
remove the fuel line from the fuel rail on the engine and route this line into a bottle or container, open the ignition for about 3 secs and see if there is fuel coming out, if there is, you either not getting power to the injectors or your injectors are clogged.
(MAKE SURE WHEN YOU ROUTE THE FUEL LINE INTO A BOTTLE, THERE IS NOTHING AROUND AREA THAT CAN CAUSE A FIRE)
If you do have fuel, check for the dropping resistor pack, make sure it is installed.
If you don't have fuel, check for blown fuse on fuel pump or bad fuel pump relay.
do these tests and let us know how results do you get.
PULSAR GTRRafi
